HELP PLEASEEEEEEEEEEEEEEE!!!! ASAP
Old Dec 15, 2005 | 08:15 PM
d16y8delsol's Avatar
Default HELP PLEASEEEEEEEEEEEEEEE!!!! ASAP
okay i was driving my del sol down my road doing about ehh 5 mph and it stalled out and doesnt wanna start....i thought maybe the gas gauge was off so i put some more gas in it.....then tried to start it and it wont start could this possibly be the fuel pump?....i need help asap please!!!
Old Dec 15, 2005 | 08:26 PM
97spooncivic's Avatar
look here https://honda-tech.com/zerothread?id=1464622
Old Dec 15, 2005 | 08:31 PM
PphamEK's Avatar
Default Re: HELP PLEASEEEEEEEEEEEEEEE!!!! ASAP (d16y8delsol)
It can be alot of things u have to describe more details. check if u have spark by takin one of the plugs out wit the wire still on it then tell sumone to crank it and look for spark. It can also be a fuel problem, put ur keys in the igniotn then turn the keys to ON and listen to a click, if i dunt here the click its probly your fuel pump. It can also be ur tps sensor.just keep on tryin testes.
Old Dec 15, 2005 | 08:35 PM
Default Re: (97spooncivic)
i dunno if that could be it.....cause the car doesnt burn oil at all but it could be it....just wish i had some oil haha
Old Dec 15, 2005 | 08:39 PM
Default Re: (d16y8delsol)
okay....it cant be the oil cause the car doesnt burn any oil at all the oil level is also fine, the car has spark, im not to sure if i hear the "click" of the fuel pump or not...
Old Dec 15, 2005 | 08:45 PM
its def the fuel pump i just went outside and listened for the click and didnt hear it at all nothing when i turned the key to the on position
Old Dec 15, 2005 | 08:49 PM
nocturnaldragon's Avatar
When you turn your key on listen to the area right above your rear storage area, your fuel pump is right below that. So if it is that, its extremely easy to get too.
Old Dec 15, 2005 | 08:54 PM
PphamEK's Avatar
u wont have time to step out of ur car a listen for a click. when u turn your key on ON it clicks for only a sec, so u gonna have to turn ur key and try to listen for a click at the same time.
crx18c1
11
Jun 18, 2007 06:42 PM
iHOPEyouCHOKE
Jun 9, 2006 02:49 AM
iHOPEyouCHOKE
Jun 2, 2006 11:02 AM
siis2fast
Jun 3, 2004 10:12 PM
