ENGINE IDLES AT 500rpm
I replaced the battery today, spark plug wires, oil change were done recently as well.
it feels liek as if the car isnt getting any power or tq at all when driving.
THe RPMs take very long and are very hard to keep high, when starting in first it takes about 8seconds for the rpm to reach about 3k and when it reaches 3k it sounds normal but still has no torque at all. I had to ride the clutch to keep the RPMS high because as soon as i let go of the gas the needle dropped hard to about 1k.
when in neutral i had to keep playing with the gas because the needle would be jumping around at about 500-700rpm. It often shut off my car completely.
Is this a fuel injeciton problem? or something bigger?
anyone have this experience?
no...the short ram intake cone fell off when installing the battery and the engine ran like that for about 15 mins. when i popped the hood i connected the cone again.
the whole intake was bumping around my engine bay alot and i tried to tighten it but i couldnt in the rain.
i didnt touch the throttle body though
sounds like u have alike a vacum leak casue im having the same problem check all your vacum lines make sure u didnt knock any off or any thing than once u get the idle to stop fluctuation adjust it to where u want it on the side of the intake manifold =>
up for this guy. I'm dealing with the same thing except I replace my timing belt (also swapped heads with another one I had been working on). definately would like to know more
also, by any chance is your car running rich ( do you smell gas ). I have that problem too.
sounds like spark plugs to me.. did you gap em right?
do a spark plug test..
(pull each spark plug wire off.. and if the engine changes idle.. then its good.. if it stays the same.. then its bad..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh2586 »</TD></TR><TR><TD CLASS="quote">sounds like spark plugs to me.. did you gap em right?
(pull each spark plug wire off.. and if the engine changes idle.. then its good.. if it stays the same.. then its bad..</TD></TR></TABLE>
We actually did do this before and cyl # 3 wire being off did not change the way the car ran, also thats when we noticed the spark plug wire boot was broken completely
Modified by br0nx finest at 12:52 PM 12/17/2005
Sep 29, 2007 08:10 PM
blueaccord90
Jun 27, 2005 01:37 PM
just4747
Sep 18, 2004 08:23 PM
looking for a new LS motor as we speak
