Need help with heater/ac controller not working in 92-95 hatch??
Old Dec 15, 2005 | 06:40 PM
HickamHatch's Avatar
Default Need help with heater/ac controller not working in 92-95 hatch??
Ok, I have a 93 civic hatch. The heater/ac unit did not work in the car.. Thought it could be the controller, but when i installed my integra dash, it still does not work. Now none of the fuses are blown under the dash or under the hood.
I am thinking it could be a relay.
What does everyone else think?
Old Dec 17, 2005 | 01:35 PM
damn, this sucks
Old Dec 17, 2005 | 01:55 PM
mluckxxx's Avatar
Default Re: (93civic96ls)
dont worry about it, be a man and take them out
Old Dec 17, 2005 | 01:57 PM
i need defroster for winter, i have no ac, took that out already ;-)
Old Dec 17, 2005 | 01:58 PM
mluckxxx's Avatar
the heat doesnt turn on at all? or does it blow out cold?
Old Dec 17, 2005 | 02:06 PM
nothing will come on.
Old Dec 17, 2005 | 02:19 PM
mluckxxx's Avatar
you said you changed the dash, check the wiring that goes to the controls
Old Dec 17, 2005 | 02:23 PM
like i said in first post. this control unit was not working BEFORE i put in the integra dash. All wiring is wired up man..
Old Dec 17, 2005 | 06:54 PM
could this be a relay?
Old Dec 18, 2005 | 06:14 PM
TRIED A NEW RELAY TODAY and it still does not work
Old Dec 18, 2005 | 06:24 PM
john666's Avatar
Default Re: Need help with heater/ac controller not working in 92-95 hatch?? (93civic96ls)
does the fan motor go on ?
Old Dec 18, 2005 | 06:29 PM
you mean the blower? the blower is not turnin on
Old Dec 18, 2005 | 06:47 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Try bypassing all the relays and putting power directly to the blower motor. A ground and power off the battery to see if the motor turns on for a moment.
Old Dec 18, 2005 | 06:50 PM
I will try this, but the stock civic motor wouldn't turn on either, now the integra motor won't work either..
It didn't start doing this untill the LS motor was swapped in.
Old Dec 20, 2005 | 08:37 PM
anyone else have any input?
Old Dec 24, 2005 | 12:30 PM
hmm
Old Dec 24, 2005 | 01:28 PM
JDM-97CX's Avatar
You probably need a blower motor.
Old Dec 24, 2005 | 01:30 PM
Default Re: (JDM-97CX)
this is the second motor i have tried..
Archerdude
Honda Civic (2001 - 2005)
Jan 25, 2014 10:05 PM
85_305
28
Jun 27, 2009 09:33 AM
nWilk666
Apr 15, 2007 02:57 PM
framici
Apr 6, 2002 05:08 PM
