AEM Fuel Rail for my 91 Teg?
The AEM Fuel Rail's on the market these days for Teg's are listed as compatible with 94-01 Integra's. I have a 91 Teg LS B18A. Will the AEM Fuel Rail being sold by AEM, part number 25-100, work on my rig? Or only 3rd gen Tegs (94-01)?
Generally most B series stuff works on almost all B series engines but in this case I'm assuming the answer is no.
Thanks.
Thanks.
yeah it'll work, it's the throttle bodies that have trouble with the stock b18a intake manifolds. If I were you I would use the money towards a intake manifold before getting a fuel rail.
Later
Later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by themilman »</TD></TR><TR><TD CLASS="quote">Thanks for the info............, I've got a Blox IM, JG 62mm TB, New OEM injectors, and Gauge/FPR installed.</TD></TR></TABLE>
I'd still pass on the fuel rail. You really don't need to look into getting one until your hitting 300whp+. Spend the money on something else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegraX »</TD></TR><TR><TD CLASS="quote">yea don't need more fuel rly...looks nice as underhood bling i guess </TD></TR></TABLE>
yea unless you have a fat wallet and want to make it a little bit slimmer
you would be surprised how much the stock fuel rail can handle. if anything i would get an adjustable fuel pressure regulator first.
Thanks, I've got an FPR installed.
I realize I don't need it, just curious if AEM rail would fit.
I found a guy selling OEM Beck Arnley injectors on Ebay about 2 years ago, for $20 each (which I bought), they retail for over $100 each.
First, I did my research (and calculations) on the stock fuel system and found that the fuel pump and injectors can adequately deliver fuel in a system up to 200hp. I have to assume that, engineered in this same manner, the fuel rail can also provide adequate fuel in a system up to 200hp.
Even with my pending exhaust and Crower 404's, adjustable cam gears, and Dyno time (see sig), I'll probably be at around 160-170hp, not 200, and I'm not taking my old DA up over 200hp with more NA build, too much $$ & time. Probably just get a newer teg in the next 1-2yrs and go turbo, its $30 per HP gain vs. $100 per HP gain with the NA build.
The square silver aluminum fuel rails off civics that fit B series look pretty good polished and usually go for about $10-$20 so I'll probably go that way.
Thanks for the advice all.
