Is this True?? B-series exhaust cam
Old Dec 15, 2005 | 02:05 PM
T_bones's Avatar
Default Is this True?? B-series exhaust cam
Is it true the all b-series vtec exhaust cams are the same size?? As in b16 & b18c5 exhaust cams are the same.... just the intake cam is different??? Done Searched... Couldnt find anything relative.
Old Dec 15, 2005 | 05:06 PM
DonF's Avatar
Default Re: Is this True?? B-series exhaust cam (TEGhasJDMfever)
No.
Old Dec 15, 2005 | 06:42 PM
Honda Bull's Avatar
Default Re: Is this True?? B-series exhaust cam (DonF)
No.... you might just think that since some people tend to just throw a Type-R intake cam on as, if you are only buying one cam, the intake will net more power than the exhaust cam.
Old Dec 15, 2005 | 07:32 PM
itrsleeper's Avatar
the itr cams have 240 deg. of intake duration with 11.5 mm of lift and the exhaust has has 235 deg. of duration with 10.5 mm of lift. with 25 degrees of over lap. the b16b has 243 deg. of intake duration with 28 deg of over lap. and yes you can only put in the intake cam. but you need to switch the stock dual springs to the exahust and for the intake atleast get some itr springs or better to run the extra valve train velocity.
Old Dec 15, 2005 | 07:38 PM
itrsleeper's Avatar
adding the exahust cam will only give you 1-2 more hp. so its ur call.
Old Dec 16, 2005 | 11:44 AM
T_bones's Avatar
Thanks everyone for the great info.
Old Dec 16, 2005 | 12:22 PM
DonF's Avatar
Default Re: (TEGhasJDMfever)
Just go to Crower.com, they have all the B-series specs on their cam page.
BryanPendleton
Dec 11, 2004 07:31 PM
skribblah
Sep 13, 2003 07:07 PM
Combustion Contraption
Sep 5, 2003 02:24 AM
Death_to_Thieves
Dec 5, 2002 11:00 AM
TGUNNER
May 2, 2002 07:38 AM
