EF LS-VTEC which pistons?
Old Dec 15, 2005 | 01:04 PM
Civicr2gs5's Avatar
Default EF LS-VTEC which pistons?
well i have plans for building my ls block for my ls vtec. the head is already done.. my question is which setup are u guys running with forge products on ur LS-vtec and i want to know how ur liking them. list the pro's and cons, specs, and i'm startin to look towards je pistons for the LS block but on their site they don't make it for LS so which should i get. this is going to be my first build on my ls block, it had pr3 piston and rods in it until it got messed up. also if there are any gaskets or lil things i need to buy for the block like oil pan gasket or bearings (unless bearing comes with the product when you buy it) its goin to be all-motor daily driven. no nirtrous or turbo... thanks
Old Dec 15, 2005 | 01:32 PM
Civicr2gs5's Avatar
Default Re: EF LS-VTEC which pistons? (Civicr2gs5)
help?
Old Dec 15, 2005 | 01:52 PM
DC2 Mang's Avatar
i would go oem again
P30 pistons (or PR3 or JDM ITR)
arp rod bolts
oem rings
acl bearings (standard size)
LS head gasket
gsr timing belt
B16 or B18c oil& water pumps
and all new gaskets all around
depending on the cams and I/H/E you can make around 190-220 whp
PS: if you dont have traction bars you should get some, EF's have horrible wheel hop due to their stock suspension configuration
Modified by JDMdc2lsVtec at 4:10 PM 12/15/2005
Old Dec 15, 2005 | 02:01 PM
shorto85's Avatar
I had CP make me a custom set of pistons for my LS/VTEC
Old Dec 15, 2005 | 02:02 PM
Civicr2gs5's Avatar
Default Re: EF LS-VTEC which pistons? (JDMdc2lsVtec)
which gasket is better to use? ls or gsr?..what gaskets are consist or lil things that i need to buy for the block except for oil pan gasket.....and plus are u sayin oem is more reliable then forge pistons etc....?
Old Dec 15, 2005 | 02:03 PM
Civicr2gs5's Avatar
Default Re: EF LS-VTEC which pistons? (shorto85)
what is ur custom spec of the piston? how are they different?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 &raquo;</TD></TR><TR><TD CLASS="quote">I had CP make me a custom set of pistons for my LS/VTEC </TD></TR></TABLE>
Old Dec 15, 2005 | 02:09 PM
DC2 Mang's Avatar
my bad, i meant to say LS head gasket, i am switching over from an LS vtec to a gsr right now so i hve alot of mixed things in my head
as far and gaskets go you should get
-intake manifold
-exhaust manifold
-cam seals
-water pump
i would also recomend getting some vtec oil and water pumps
PM me fore deatils and ill let you know what a good set up would be and it would save you money too
Old Dec 15, 2005 | 06:39 PM
lsvtec1.9lcrx's Avatar
i have a built ls/vtec and i would use jdm itr pistons..i have the 82mm and compression is 11:8 265 psi.runs great on 93 pump gas.use oem b18 a/b head gasket..make sure your oil port tap seals..use some quick steel over it after screwing it in..also make sure you get a vtec oil pump..
Old Dec 15, 2005 | 10:01 PM
dc4rider's Avatar
Default Re: (lsvtec1.9lcrx)
witch head r you usein?
and wat rods?
Old Dec 16, 2005 | 05:26 PM
stock shot peened rods.93 gsr pr3 head(b16)..wild port work..
Old Dec 18, 2005 | 09:43 AM
NAlover's Avatar
Default Re: (seditionONE)
i wanna build a good lsvtak which pistons would be better??
the block is bored .25..
i'm thinking CTRs or JDM ITRs but don't know ??...
i have Toda cams which ain't thingking on going past 8700- 8900rpm so will the ls rods be safe at such rpm with arp rod bolts??? or can i use my b16 rods???? help me
Old Dec 18, 2005 | 09:56 AM
DC2 Mang's Avatar
Default Re: (NAlover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAlover &raquo;</TD></TR><TR><TD CLASS="quote">i wanna build a good lsvtak which pistons would be better??
i have Toda cams which ain't thingking on going past 8700- 8900rpm so will the ls rods be safe at such rpm with arp rod bolts??? or can i use my b16 rods???? help me </TD></TR></TABLE>
Sent you a PM about this
deemee
Northeast (Sales)
Nov 25, 2010 11:50 AM
Civicr2gs5
Dec 15, 2005 02:18 PM
slayersluck
Dec 6, 2004 11:01 AM
tfalconier
Aug 18, 2004 07:56 PM
SupaFly_Honda
Oct 3, 2003 05:45 PM
