FS: h22 h22a turbo setup 291whp @ 8psi (also aem uego, injectors etc..)lots o pics
this is the partial turbo setup off my integra because i've decided to step it up quite a bit. @15psi this setup put 4 lengths on a high 12second ls1 car.have some older pictures of these parts, will have more within the week
<U>p.s. no parting out of theturbo kit</U>
(new pics 1-29-06, everythings a little dirty from disassembly)
-turbonetics t3/t4 60-1 (.82ar housing stage 5wheel polished to4s compressor housing-4in inlet 2 1/2 outlet)
-revhard cast manifold with 35/38mm external gate, no cracks
-35mm deltagate 2, with dumptube
-slightly sharper than 90 degree 2 1/2" bend with dp flange attached (i had a side exit dp so i will just include the use able part)
looking for 1000 for all this, prefer to keep it together
also have for sale for best offer
-jdm h22a shortblock 90% complete (good compression/leakdown numbers but has scratches at the top of each bore, ran fine) moroso pan not included, only stock pan (needs waterpump tube, misc bolts, ks, and oil pressure sensor. I had to take all these parts off because they were missing on my built block)
-AEM UEGO non gauge type new in box (only mocked, then decided on a plx)
-gm boost solenoid with pigtail new in box
-903cc semins deka injectors
-460cc rx7 peak and hold injectors
-aem h22 p/s pulley (red)SOLD
-h22a balance shaft plug billet aluminum SOLD
Modified by b16hybridsol at 11:25 AM 12/20/2005
Modified by b16hybridsol at 5:36 PM 12/31/2005
Modified by b16hybridsol at 3:28 AM 1/8/2006
Modified by b16hybridsol at 11:57 PM 1/26/2006
Modified by b16hybridsol at 11:58 PM 1/26/2006
Modified by b16hybridsol at 7:19 PM 1/29/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1Monster »</TD></TR><TR><TD CLASS="quote">how much for the rx7 injectors and how well do they work? Do you need a resistor box?</TD></TR></TABLE>
just like dsm injectors, you need a resistor box to run them. They came out of a buddys n/a rx7 because hes going turbo
just out of curiousity why do you need it. It won't fit the normal h22 p/s pumps, i had to modify my pump to get my stock teggy line (in the pic) to fit right. i'll sell the line though if you need it, still got the p/s pump also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping »</TD></TR><TR><TD CLASS="quote">i'm mew here guys.wow i didn't know you could put a h22 in a teggy.
what's up b16hybridsol....
what kind of set up are you going w/now.</TD></TR></TABLE>
hey man hows it going. I decided to go bigger yet again. head built by dart rediculous hybrid turbo from innovative, 1600cc injectors. should be over 700wheel, you know how it is ha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol »</TD></TR><TR><TD CLASS="quote">just out of curiousity why do you need it. It won't fit the normal h22 p/s pumps, i had to modify my pump to get my stock teggy line (in the pic) to fit right. i'll sell the line though if you need it, still got the p/s pump also</TD></TR></TABLE>
o if its not the h series one then its cool its cuz i need it for my swapped accord thanks anyways
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roll5104life »</TD></TR><TR><TD CLASS="quote">
o if its not the h series one then its cool its cuz i need it for my swapped accord thanks anyways</TD></TR></TABLE>
no problem
no problem
hey man hows it going. I decided to go bigger yet again. head built by dart rediculous hybrid turbo from innovative, 1600cc injectors. should be over 700wheel, you know how it is ha</TD></TR></TABLE>
awesome man let me know how it goes ok.
harv
harv
SOLD
-rx7 injectors
-balanceshaft plug
-p/s pulley
Modified by b16hybridsol at 10:29 AM 12/20/2005
-rx7 injectors
-balanceshaft plug
-p/s pulley
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude94 »</TD></TR><TR><TD CLASS="quote">Just recieved Parts, Great seller
thanks man
up for the other peeps, help fund my new setup please
</TD></TR></TABLE>thanks man
