converting to obd1
Old Dec 15, 2005 | 09:44 AM
flatblackhatch's Avatar
Default converting to obd1
i have a ob0 hf crx obd1 ecu obd2 motor i got the obd0 jumper harness i know i need to get the obd0 engine harness but will i need new injectors and dizzy and distributor the shop im talking to said i wont that they will work is this tru and what else do i need to do this
Old Dec 15, 2005 | 11:38 AM
e jay one's Avatar
Default Re: converting to obd1 (flatblackhatch)
what motor and what obd do you want it?
Old Dec 15, 2005 | 12:20 PM
west nile's Avatar
As stated already what obd2 motor is it and did it come with the obd2 engine harness? Also dizzy=distributor. Anyway since you have obd2 injectors if you were to get an obd0 engine harness you would just need to eliminate the resistor box, and you would just need to repin the distributor since it will be wired up for obd0 and it is an obd2 distributor.
Old Dec 16, 2005 | 11:10 PM
Default Re: converting to obd1 (west nile)
obd2 crvtec and had the engine harness dizzy and distributor for obd2
Old Dec 16, 2005 | 11:39 PM
civickiller's Avatar
dizzy = distributor so dont know what you mean when you say dizzy and distributor
Old Dec 16, 2005 | 11:43 PM
88_DX's Avatar
i would use obd0 injectors, just to keep it eazy. And also get the stock harness, make sure its the same year and model as your car. For the obd-2 distributor it only has one plug but obd0 and obd1 have 2 plugs. since you have a obd2 harness cut the distributor plug off and make a short harness that goes from the obd2 plug then to the stock plugs. Hope that helps
Old Dec 17, 2005 | 02:52 PM
Default Re: converting to obd1 (88_DX)
thank you fellas let you know how it goes
Old Dec 17, 2005 | 03:05 PM
NikoZai's Avatar
seems like this might be a bit over your head.. give me a call at Rywire
http://www.rywire.com
Old Dec 17, 2005 | 03:10 PM
hatchinprogress's Avatar
Default Re: converting to obd1 (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">seems like this might be a bit over your head.. give me a call at Rywire
http://www.rywire.com</TD></TR></TABLE> hey peter i just called you and left a message....give me a call
integrawow
Apr 20, 2009 09:26 AM
julianaa
Oct 3, 2007 12:43 PM
DIYMIKE
Feb 23, 2007 09:06 PM
