need a lil help my car is smoking
Old Dec 15, 2005 | 06:06 AM
illmaticimports's Avatar
Default need a lil help my car is smoking
hey i just put a new head on my car had it profeesionally done and adjusted new every thing and my car smokes like some white smoke it cause away for a lil as soon as i get my oil changed but after for like driving for like 40 min it starts to smoke again its eFFing annoying can any one help me WHY
Old Dec 15, 2005 | 06:14 AM
LL2009's Avatar
Default Re: need a lil help my car is smoking (illmaticimports)
if is white smoke you might be running rich.
Old Dec 15, 2005 | 06:17 AM
how would i regulate rich or lean
Old Dec 15, 2005 | 06:51 AM
f2rider's Avatar
Default Re: (illmaticimports)
You can regulate rich or lean with an adjustable fuel pressure regulator. Thats probably the cheapest way. But I've always been told that white smoke would be coolant not fuel which makes since because you just changed your head. Don't change the oil for a few miles and check to see if it looks like chocolate milk. That would tell you that you probably have a problem with your head gasket. You probably could get a leak down test done also. Good luck.
Old Dec 15, 2005 | 07:07 AM
drtyhatch's Avatar
Default Re: need a lil help my car is smoking (LLEO245)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLEO245 &raquo;</TD></TR><TR><TD CLASS="quote">if is white smoke you might be running rich.</TD></TR></TABLE>
you are wrong...think before you give people bad info.
White smoke is coolant. Sounds like a headgasket problem to me, could have been put on backwards i guess.
Old Dec 15, 2005 | 07:18 AM
chown -R us .base's Avatar
Default Re: need a lil help my car is smoking (drtyhatch)
nicorette FTW.
Sorry, I couldn't resist.
Old Dec 15, 2005 | 02:02 PM
k well i know for a fact that the head gasket is not leaking casue i hold very good compression and that its brand new out of hte box and on correct cause i mad sure of that so do you hvae any more sugestions ike i said it dies down wen i have my oil changed and comes back wen i get low on oil plus kinda burn oil fast wat could that be
Old Dec 15, 2005 | 04:46 PM
f2rider's Avatar
This may be a long shot but I've seen this happen before. My brother changed his head gasket on his DA, it ran great for a couple of days and then the white smoke came back. At that point we decided to just pull the whole motor and do a rebuild. Well after we got the motor out and we were taking off the head we noticed that one of the head studs either came loose or we never tightened it all of the way. You might want take out the cams and check them.
Old Dec 15, 2005 | 04:57 PM
did that the heads at torqed at 61 ft so they are good i mean wen its cold it smokes a lot but wen it warms up it only smokes if u really womp on it like 35-7 grand (rpm) so i duno
Old Dec 16, 2005 | 05:08 PM
can any one else help
Old Dec 16, 2005 | 07:47 PM
CRXb18Turbo's Avatar
White don't mean running rich..
Old Dec 16, 2005 | 07:56 PM
jh2586's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f2rider &raquo;</TD></TR><TR><TD CLASS="quote">This may be a long shot but I've seen this happen before. My brother changed his head gasket on his DA, it ran great for a couple of days and then the white smoke came back. At that point we decided to just pull the whole motor and do a rebuild. Well after we got the motor out and we were taking off the head we noticed that one of the head studs either came loose or we never tightened it all of the way. You might want take out the cams and check them.</TD></TR></TABLE>
those head bolts are supposed to be torqued to "yield" which means you need a torque wrench that is capable of up to 250 ft lbs.. check the manufacturer's specs
Old Dec 16, 2005 | 08:39 PM
ComptonsF1NEST's Avatar
white smoke is coolant--even if the guy is a professional doesnt mean he did a gret job on it.
Old Dec 16, 2005 | 08:45 PM
watsvtecEK's Avatar
Default Re: (ComptonsF1NEST)
black smoke is rich... i dont think it smokes when its lean.
Old Dec 16, 2005 | 08:50 PM
Dartanian's Avatar
Default Re: (D 2da A9)
A new head or a used head? If it was used, was it resurfaced? Is the compression consistent between cylinders?
Old Dec 17, 2005 | 07:53 AM
used head but the compression even i think at like 180 all 4 not resurfaced but it did this before i even changed the head think that it could be my injectors or my rings
Old Dec 17, 2005 | 08:18 AM
Sar Face's Avatar
it could be alot of things, poor install, warped head, bad rings, or blown seals, hard to tell, but it's sounds like it's burning coolant. Take it to a repuitable shop if you can't figure it out your self. I had the same problem but i was building my engine found out the shop didn't know what they were doing and i was told they were good. Do your homework before it happens to someone else
Old Dec 17, 2005 | 05:01 PM
Old Dec 18, 2005 | 11:01 AM
see this is the thing if it a collant thing than why does it goe away after a while and now here its rainging and cold and wen i drive it doesnt happen wtf i dont get it
Old Dec 18, 2005 | 02:00 PM
Sar Face's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illmaticimports &raquo;</TD></TR><TR><TD CLASS="quote">see this is the thing if it a collant thing than why does it goe away after a while and now here its rainging and cold and wen i drive it doesnt happen wtf i dont get it</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illmaticimports &raquo;</TD></TR><TR><TD CLASS="quote">hey i just put a new head on my car had it profeesionally done and adjusted new every thing and my car smokes like some white smoke it cause away for a lil as soon as i get my oil changed but after for like driving for like 40 min it starts to smoke again its eFFing annoying can any one help me WHY</TD></TR></TABLE>
so it just smokes whenever it wants to? You said it could be your rings, what's the history with your engine?need to know to a little more background
Old Dec 18, 2005 | 02:06 PM
Sar Face's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drtyhatch &raquo;</TD></TR><TR><TD CLASS="quote">
White smoke is coolant. Sounds like a headgasket problem to me, could have been put on backwards i guess.</TD></TR></TABLE>
headgasket backwards lol, that's how you miss up dowel pins. Head would even go on, that means the car won't start. Don't think so..
Old Dec 18, 2005 | 04:00 PM
head on good gasket good smokoe happens wen i rev about after like 5-6 grand (rpm) duno???? lol and it nociteced that is smokes more wen its warm out side than aposed to cold my momtors got 186 thosand miles on it and a b1 head a1 block intake exhaust and headers think that it could be my cat maybee i duno thanks pleasr reply
Old Dec 18, 2005 | 05:40 PM
Sar Face's Avatar
how bad is the smoke, little or alot? does it smoke underload or just sitting there.did you replace the head studs with new oem ones
Old Dec 19, 2005 | 04:08 PM
its a little bit and its kinda blueish white???
Old Dec 19, 2005 | 04:42 PM
TurdBlown Teg's Avatar
if its cold then look around at other cars they smoke too. so give it up. i am doing soo but i know where my problem is.
