Looking for tuning advice from people with Toda spec Cs!!!!!
Old Mar 16, 2002 | 11:52 AM
powerfulperformance's Avatar
Default Looking for tuning advice from people with Toda spec Cs!!!!!
I am looking for some advice on tuning before i go to the dyno, yes I know that i need to tune it on the dyno and every car is different. for right now I need some advice on setting up my car until i have time to go to the dyno.....
mods..
apec vtec controller....set to 6700..
toda header
toda spec c
rollerwaves pistons
toda camgears.....
440cc injectors...
godspeed ecu..
42 psi....
any suggestions on what my psi should I be at, my vtec point and cam gear settings ..... the car has everything set at zero................
Old Mar 16, 2002 | 01:57 PM
coquinn's Avatar
Default Re: Looking for tuning advice from people with Toda spec Cs!!!!! (powerfulperformance)
Sorry, but if you are needing help on how to work an A/F gauge, then you definately don't need to be "tuning" your car. I think you've jumped in way over your head ...
Old Mar 16, 2002 | 02:24 PM
Toda Party's Avatar
mods..
toda header
toda spec c
rollerwaves pistons
toda camgears.....
440cc injectors...
godspeed ecu..
42 psi....
hopefully you don't have a stock valvetrain
Old Mar 17, 2002 | 01:40 AM
typer77's Avatar
New User
Default Re: Looking for tuning advice from people with Toda spec Cs!!!!! (Toda Party)
I have an Endyn worked head/ RW pistons/ toda B cams and valvetrain... and only 310 (as opposed to your 440) injectors, the car is rich as heck. I need to get computer management system. good luck!
mugenintegra16
May 28, 2002 09:47 PM
Spyderwebab
Mar 6, 2002 02:01 PM
96tegsr
Oct 31, 2001 07:20 AM
Black R
Aug 23, 2001 07:05 AM
