how much should i mill my gsr head for my setup??
Old Dec 14, 2005 | 09:13 PM
Scubster's Avatar
Default how much should i mill my gsr head for my setup??
alright so heres my setup
b20z block (stock pistons with cut valve reliefs)
gsr head with s2s2 cams
stock oem 3 layer headgaket
now i know the compression on this is gonna be pretty low. according to c-speedracing i am looking at about a 10.2 compression ratio. i want to bump up the compression a little WITHOUT GETTING NEW PISTONS. So my question is how much should i take off the head to get a little bit more compression. Should i just take off a layer of the headgasket? Any experienced engine builders please chime in!! thanks in advance
Old Dec 15, 2005 | 03:00 AM
fmrprojects's Avatar
Default Re: how much should i mill my gsr head for my setup?? (AllM0tadc2)
You cant really mill a gsr head that much, maybe 20 thousandths max. The S2S2 you are planning to use may not make its full potential because the compression is kinda on the low side. Try using stage 1's. My friend had a similar set-up with port and made 195hp 141tq
hYbRid_Eg6
Dec 20, 2009 07:01 PM
AlwayzSpoolin
Jan 17, 2007 05:53 PM
johnzm
Mar 11, 2005 04:19 PM
jeremy.
Jul 13, 2003 08:31 AM
OBD-One-Kanobe
Sep 17, 2001 02:54 PM
