Just attempted to polish my GSR blades. Let me know!
Old Dec 14, 2005 | 07:42 PM
Visionist's Avatar
Default Just attempted to polish my GSR blades. Let me know!
220, 400, 800, 1000, 2000
mothers polish
all hand sanded!!!! i was just trying it out
i still need to buff the rims and use a polishing ball on it !
BEFORE
220
800
1000
NOW I NEED TO BUFF WITH SOME MOTHERS AND THEN USE MY POLISHING PAD!!
feedback would be nice what do you think i can do to make this bling?
Old Dec 14, 2005 | 07:54 PM
Chiggah's Avatar
Default Re: Just attempted to polish my GSR blades. Let me know! (jdmfantasy)
my SIR wheels are polished,
dont use a ball, use a rotary polisher - get as much contact as you can, i used a dremel with a soft brush and i had so much swirls!
u dont have to use so much polish either, just make sure u add some water on it, until the whole rim becomes black then wipe off
it should turn out good!
keep it up!
Old Dec 14, 2005 | 07:55 PM
Undercover_Skank's Avatar
Default Re: Just attempted to polish my GSR blades. Let me know! (Chiggah)
keep us posted on how its gonna look...
Old Dec 14, 2005 | 07:56 PM
foam's Avatar
looks good so far
Old Dec 14, 2005 | 07:58 PM
one^g's Avatar
Default Re: (foam)
how long it take to do that?.
Old Dec 14, 2005 | 08:00 PM
Local Tuner's Avatar
Default Re: (foam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foam &raquo;</TD></TR><TR><TD CLASS="quote">looks good so far </TD></TR></TABLE>
accordselux's Avatar
Me Gusta History
Default Re: (one^g)
did you strip off the clearcoat?
And I can see some fine lines in it, shouldnt be there after 1000. Go back a few levels, and then keep going, i'd stop at 1600 or so and then step up to the polish. I used aluminum polish and it worked great.
Old Dec 14, 2005 | 08:52 PM
johnxboi's Avatar
Default Re: (accordselux)
go 2000
Old Dec 14, 2005 | 08:53 PM
papito_85's Avatar
Default Re: (foam)
Old Dec 14, 2005 | 09:04 PM
Options's Avatar
All Secrets Known
Wow....not bad for hand sanding.
Old Dec 14, 2005 | 09:13 PM
UncleD's Avatar
Default Re: Just attempted to polish my GSR blades. Let me know! (Options)
Check my sig on the wheels...see if you like dem joints
Old Dec 14, 2005 | 09:23 PM
hushypushy's Avatar
damn the first pic is pretty ratty, even by now they look pretty good
Old Dec 14, 2005 | 10:53 PM
eghatch4sale's Avatar
ill be doing this once the weather breaks
Old Dec 14, 2005 | 11:04 PM
Anthony's Avatar
Mr. Fuch-yu
Default Re: Just attempted to polish my GSR blades. Let me know! (eghatch4sale)
Post more pics once polished. I'd like to see the end product.
-Red
Old Dec 14, 2005 | 11:11 PM
JRSC EM1's Avatar
You should step up to 1200, 1500 then 2000 BEFORE you use some polish on them...
Old Dec 14, 2005 | 11:21 PM
Anthony's Avatar
Mr. Fuch-yu
Default Re: Just attempted to polish my GSR blades. Let me know! (JRSC EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSC EM1 &raquo;</TD></TR><TR><TD CLASS="quote">You should step up to 1200, 1500 then 2000 BEFORE you use some polish on them...</TD></TR></TABLE>I'm polishing a valve cover right now (write-up in progress) and I went with:
1.) 240 grit
2.) 320 grit
3.) 400 grit
4.) 600 grit
5.) 1200 grit
6.)1500 grit
7.) 2000 grit
8.) 2500 grit
I would like to go with finer grit than that to remove any and all of the fine swirls left in the metal but the local paint shop doesn't carry anything finer than 2500 grit. Does anyone know where I could order some finer sandpaper?
-Red
Old Dec 14, 2005 | 11:42 PM
three stars, two bars's Avatar
From: knee deep among your wreckage and uncertainty
Default Re: Just attempted to polish my GSR blades. Let me know! (nitrared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrared &raquo;</TD></TR><TR><TD CLASS="quote">I'm polishing a valve cover right now (write-up in progress) and I went with:
1.) 240 grit
2.) 320 grit
3.) 400 grit
4.) 600 grit
5.) 1200 grit
6.)1500 grit
7.) 2000 grit
8.) 2500 grit
-Red</TD></TR></TABLE>
Congratulations you won wheel polishing, and thread jacking, I wish I had a cookie for you but all I have is this .
Nice blades JDM fantasy, I was hoping to see some final shots though, keep us updated.
Old Dec 14, 2005 | 11:53 PM
iam7head's Avatar
Default Re: Just attempted to polish my GSR blades. Let me know! (iheartmyceeareks)
are you wet sanding? because if you are, you shouldn't getting so much fine lines, get it done right now or you'll have to come back later down the line to finish it off.
Old Dec 15, 2005 | 05:20 AM
kleanlscivic's Avatar
post the final product for sure
Old Dec 15, 2005 | 05:22 AM
jDm_jeremy's Avatar
lookin good so far
Old Dec 15, 2005 | 06:05 AM
Robstunner4's Avatar
Default Re: Just attempted to polish my GSR blades. Let me know! (jDm_jeremy)
do 1500 and 2000. use rubbing compound followed by mothers billet polish ($13 stuff not $4)
use a buffing wheel for the polish. heres my polished blades
wetsanding should be done too, will help
Old Dec 15, 2005 | 06:12 AM
DFW's Avatar
DFW
Default Re: Just attempted to polish my GSR blades. Let me know! (Robstunner4)
what's the difference between the reg mother polish to the billet polish? do you have any before pictures of your blades?
Old Dec 15, 2005 | 06:16 AM
Me Gusta History
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyceeareks &raquo;</TD></TR><TR><TD CLASS="quote">
Nice blades JDM fantasy, I was hoping to see some final shots though, keep us updated.</TD></TR></TABLE>
Actually, he did it the right way. He was showing what he did to get results, and asked a viable question that the OP should be asking right now to get finer paper to be able to finish this right.
Strip off clearcoat: I used aircraft remover and it removed it very easily. may have to do touch ups to get everything off.
Wetsand- keep the damned thing wet, wash it off every time you've done a section, redip, change paper frequently (every 3 or 4 dips).
Start with 220-400-600-800-1000-1200-1400-1500-2000. Then I used aluminum polish followed up by 3m rubbing compound. Came out like a mirror.
Then all you have to do is find a way to keep it like that...
Old Dec 15, 2005 | 07:14 AM
Default Re: Just attempted to polish my GSR blades. Let me know! (accordselux)
heres what i did:
1.) Sandlbast
2.)wet sand with 200/400/800/1000/1500/2000
3.) rub on some rubbing compound i used 3m fine grit
4.) rub on some mother incredible billet (the $13 stuff works TONS better than the $3 stuff)
( i used a loose cotton wheel for the polishing compound, it turned out alot better than doing it by hand)
Old Dec 15, 2005 | 07:19 AM
heres some helpfull links
http://www.caswellplating.com/buffs/buffman.htm
https://www.caswellplating.com/kits/complete.htm#
