clutch, pressure plate; cable, hyrdro
i want to use an itr pressure plate in a y1 cable transmission. i did some researach and found that the pilot bearings are also the same, but the throwout bearings are different. so if i am using the entire itr clutch/flywheel/bearing assembly with a cable tranny, what do i need to get that wont work from the itr?
The clutch disk is a different spline count that what you will find on the cable trans (excpet YS1), as well as the release bearing. No way around it really. Get a YS1, or get a correct clutch.
knightsef-eg
Sep 17, 2008 12:07 PM
turkishEF
Dec 6, 2007 08:51 PM
stockcrix1616
Nov 30, 2006 08:47 AM
Beau Gotti
Feb 27, 2006 09:40 PM
