Front End Help...
Old Dec 14, 2005 | 02:46 PM
g-ride-si's Avatar
Default Front End Help...
Im wondering what could cause my car to drive so shitty. my front end just has a very loose feel to it. at first it seemed like a bad shock but they are all good(sounds like a metal on metal thud when i hit holes/cracks/anything but perfect road), ive checked all the bolts to make sure they aren't loose. sometimes it actually pulls the steering wheel out of my hand, and in the rain its just plain unsafe to drive. i know my bald tires dont help but that is not the only problem. could this be the infamous steering rack bushing?, maybe a ball joint? can a bad cv joint cause problems like this because i know my passenger side is bad?
thanks in advance for any help.
Old Dec 14, 2005 | 02:54 PM
migizzel's Avatar
Default Re: Front End Help... (g-ride-si)
well you know that having bad tires don't help i just rebuild my front end two days ago replaced everything except my rack and is a sweeet TIGHT ride to drive now my recommendation would be to rebuild the front end they sell kits that come with everything you need on eBay for like 160 shiped not a bad price considering that an upper control arm is like 120 plus at the parts store like autozone.
once you rebuild it all you'll need in a good alignment and your set.
Old Dec 14, 2005 | 03:43 PM
Crx Jimmy's Avatar
check tie rods for play as well
Old Dec 14, 2005 | 04:21 PM
migizzel's Avatar
Default Re: Front End Help... (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">check tie rods for play as well</TD></TR></TABLE>
the kit i mentioned comes wit 2 upper control arms,2 lower ball joints, new sway bar endliks with bushings 2 inner tie rods 2 outerr tie rods
Old Dec 14, 2005 | 06:40 PM
Schurke's Avatar
engine mount?
Old Dec 14, 2005 | 10:34 PM
g-ride-si's Avatar
hopefully it will quit snowin and raining so i can get it out to my friends garage so i can take a look at it.
foxjaeger
Mar 12, 2009 09:31 AM
acurater
Jan 20, 2008 10:03 PM
adamkob32
Suspension & Brakes
14
Apr 13, 2006 08:05 AM
haophat
Oct 5, 2005 02:24 PM
