K in your Rex? Keep your cluster!
Old Dec 14, 2005 | 02:31 PM
ComposiMo's Avatar
Default K in your Rex? Keep your cluster!
Ever since we started researching the K swap for a customer project, everyone has been telling us that a cluster swap would be required... well, not one to buck trends completely, we did decide to investigate it a bit more. Well, after a bit of fiddling and looking around, we figured out that if you use the cable VSS from the stock single-cam tranny (in this case a D16A6 Si tranny out of a 90 Si), you can make the cable VSS work... so you don't have to go buy an expensive cluster, and try to figure out the wiring
Picture showing the cable VSS installed in the K20A tranny
The only modification you have to do, is to drill a new hole in the SOHC VSS moutning bracket as shown
Also, the hole in the SOHC uses a 10mm bolt... in the K, it uses a 12mm bolt. So the hole has to be made big enough for that.
Here are the two VSS's side-by-side. The SOHC is a tad bit shorter, but the gears engage just fine, and its worked so far here.
You also have to use a short 12mm, not a longer one. The one we are using here is the shorter of the two 12mm bolts
All bolted up and ready to party!
Anyway, just thought we'd pass along this bit of tech info for all you K-Rexers out there if you don't already know about it Hope it helps some in your quest for powah!
Old Dec 14, 2005 | 02:34 PM
JapJunkie's Avatar
Default Re: K in your Rex? Keep your cluster! (ComposiMo)
Old Dec 14, 2005 | 02:46 PM
HT Chaplain's Avatar
Loved
knowledge
Old Dec 14, 2005 | 02:55 PM
Smokinsax's Avatar
The Boot
its like LEGOS...
Old Dec 14, 2005 | 02:58 PM
Suck my DX's Avatar
Default Re: (Smokinsax)
sweet
Old Dec 14, 2005 | 03:09 PM
user 98292739's Avatar
awesome find!
Old Dec 14, 2005 | 04:46 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (Rexified)
Thats awesome I never wanta give up my UK cluster not even for a K.
Now I can have both!
Old Dec 14, 2005 | 04:53 PM
ExplicitSpeed360's Avatar
Banned.
Default Re: (Ace$nyper)
good work! kinda like my H22 swap in my crx you are able to get away taking the hole elec. vss unit out of the hydro h22 tranny and replace the hole unit with the D series you just need to make a new longer tab like you did
Old Dec 14, 2005 | 05:25 PM
kid-honda's Avatar
Great info
I knew there had to be a way.
Old Dec 14, 2005 | 05:27 PM
HatchBox's Avatar
Skoobie no more...
Default Re: K in your Rex? Keep your cluster! (kid-honda)
are the gears identical?
If one smaller it would affect the speedometer.
Is the Speedometer correct?
Old Dec 14, 2005 | 05:31 PM
trrbl1bmx's Avatar
Good work!
Old Dec 15, 2005 | 05:46 AM
ComposiMo's Avatar
Default Re: K in your Rex? Keep your cluster! (HatchBox)
Thanks guys! Happy to help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">are the gears identical? </TD></TR></TABLE>
Yep, they are... diameter and tooth count is the same, as well as pitch. The only difference is the physical height of the gear, as seen in the picture. But the shorter D gear engages nicely on the diff ring.
Old Dec 15, 2005 | 05:47 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Old Dec 15, 2005 | 06:52 AM
CRXB16T's Avatar
Good job! My friend was theorizing something like this with using the s2k cluster in my ef with my b16 swap.
Old Dec 15, 2005 | 09:25 AM
d357r0y's Avatar
Default Re: K in your Rex? Keep your cluster! (CRXB16T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXB16T &raquo;</TD></TR><TR><TD CLASS="quote">Good job! My friend was theorizing something like this with using the s2k cluster in my ef with my b16 swap.</TD></TR></TABLE>
Won't work.. the electronic VSS sends a signal to make the s2k cluster work. Search h-t for s2k clusters on the EF forum and you'll see there is a LOT of work to get it working correctly in our cars. Easiest to stick with a cable driven or something that doesn't requre a different pulse to make the speedo work. Of course.. easiest isn't always best
Old Dec 15, 2005 | 10:24 AM
fracas's Avatar
Wish I had a K!!!
Old Dec 15, 2005 | 10:30 AM
CRXB16T's Avatar
Default Re: K in your Rex? Keep your cluster! (d357r0y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">
Won't work.. the electronic VSS sends a signal to make the s2k cluster work. Search h-t for s2k clusters on the EF forum and you'll see there is a LOT of work to get it working correctly in our cars. Easiest to stick with a cable driven or something that doesn't requre a different pulse to make the speedo work. Of course.. easiest isn't always best </TD></TR></TABLE>
I don't know the subject as well as he does. I remeber him saying there is a really easy way to get this to work.
Old Dec 15, 2005 | 10:37 AM
Rywire's Avatar
Ya, I hate myself! I sold my edm vt cluster allready! Bah! I totally looked at my vss, then at the k one, and said... HMMMM But being in a rush, and no time for r&d I just converted to elec vss and ran the SHITTY ASSZ jdm cluster! Man... I hate it!
PS, as mentioned before its very easy to convert to a electronic vss for any of the newer style clusters
Old Dec 15, 2005 | 12:05 PM
brx017's Avatar
Wash your hands John...and check your IMs.
Good info, BTW.
Ldo
Sep 1, 2008 07:20 PM
Nightfox
Nov 20, 2007 06:22 PM
crxtreme27
Jan 19, 2005 05:48 PM
toslowhatch
Nov 18, 2004 02:35 PM
wickedEFguy
Dec 16, 2002 03:51 PM
