Air/Fuel Meter Question ?
What wire on the computer would i tap into to get the O2 signal wire, to hook up an Air/Fuel meter ? Color and pin location would be great ! The car is a 2000 GSR .
***96 and up Integras, including the following body styles: GS, GS-R, LS, and RS
For the most part, as with the Honda's, the O2 sensor signal wire will be a white wire, possibly w/ black stripe on it.
94-98 Integra 1.8L
Look for the computer of the vehicle or PCM. Go to pin D14 which is a solid white wire, or go directly to the sensor and tap into the white wire there.
94-98 Integra 1.8L
Tom O
I've been thinking about getting an Air/Fuel Ratio gauge...would you be able to post up what you did to install, and any pics if possible? If so then thanks...
My install was pretty simple, took ten minutes. I took a 2" hole drill and drilled out the dimmer switch for the interior lights on the dash, then pushed in the A/F meter. I ran the purple wire to the white/blk stripe (D14 or whatever I said in previous post), stripped some insulation from that wire and wrapped and soldered the purple wire to it. Then I ran the red wire to the fuse box and pulled the cigarette fuse, stripped the end of the wire, placed it on the end of the fuse, then slid the fuse back into place. And for the life of me, I can't remember where I grounded the black wire to....
...oh yeah, I grounded that near the ECU where I had my VTEC light grounded to also. HTH
Tom O.
...oh yeah, I grounded that near the ECU where I had my VTEC light grounded to also. HTHTom O.
supersmokinhonda84SI
Mar 4, 2008 08:16 AM
