48 hour CRX rebuild - just about done!
Old Dec 14, 2005 | 01:05 PM
atc5's Avatar
Default 48 hour CRX rebuild - just about done!
Started monday night, here's what is done:
-rack end bushing
-new head w/ 40k miles, milled, hot tanked
-metal head gasket
-dc header
-mugen motor mounts
-mugen trailing arm bushings
-new lower tie rods
-new upper A arms
-new bushings in front LCA's
-ITR rear LCA's
-ground control/koni's all around
-new timing belt
-new water pump
-new valvecover gasket and cam seal
-new IM gasket
-rebuilt stock front calipers
-hawk hps pads front
-new trans - zc gears, si final drive, and QUAIFE!
-new prothane torsion bar bushings
-honda MTF
-Motul brake fluid
-stainless lines
-jun lightened flywheel
-ACT clutch and PP
This sucker is daily driving, track ready (after an alignment of course)!
Gonna feel like a brand new car....can't wait to get it off jackstands after we finish the brakes tonight.
big middle finger to the dood that jacked me on the fastbrakes kit i bought off him on HT. LAME
Modified by atc5 at 3:20 PM 12/14/2005
Old Dec 14, 2005 | 02:16 PM
Its me DUB's Avatar
Default Re: 48 hour CRX rebuild - just about done! (atc5)
good luck - hope you don't run into any probs.
31flavorscivic's Avatar
Wow. You're hardcore. Good luck with that.
Who scammed you? Post his name up for all to see.
Old Dec 14, 2005 | 02:21 PM
atc5's Avatar
no probs yet!
the rack end bushing was evil..but I didn't do that, charlie of Top Setup K20EG fame did it.
Charlie has the skills to build em right the first time.
Old Dec 14, 2005 | 03:09 PM
bmilt*336's Avatar
good luck
Old Dec 14, 2005 | 03:18 PM
Tyson's Avatar
Default Re: (atc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atc5 &raquo;</TD></TR><TR><TD CLASS="quote">no probs yet!
the rack end bushing was evil..</TD></TR></TABLE>
yeah it sucks i admit.
Old Dec 15, 2005 | 08:08 AM
atc5's Avatar
as of 2am last night, it's DONE!
few things remaining....
I need 2 new front forks..the 14mm bolt is jacked on both sides.
Gotta setup the coilovers to a good ride height
AC belt and pulley spun off at startup, lil too tight there.
Bleed the brakes one more time
This thing drives like a CHAMP! The steering and overall front end feel is fantastic. I'm VERY happy and cannot wait to dial this in.
TopSetup CRX #3!
Old Dec 15, 2005 | 09:20 AM
Tyson's Avatar
Default Re: (atc5)
so are you a REB believer now?
Old Dec 15, 2005 | 09:31 AM
atc5's Avatar
a rebuild believer?
YES, absolutely.
Old Dec 15, 2005 | 09:43 AM
2nxcrx's Avatar
Damn son where are the pictures?
Old Dec 15, 2005 | 09:46 AM
Tyson's Avatar
Default Re: (atc5)
REB rack end bushing!
Old Dec 15, 2005 | 09:50 AM
atc5's Avatar
no time for pics, we moved at such a fast pace.
ah, REB
rack end bushing
TOTAL believer.
Here's the thing...the one that was in the car looked fine, no visible wear perse.
I wonder if the tolerances are so close on that thing that ANY wear will produce the REB shake.
Just glad it's done...merry christmas to me and my CRX.
Old Dec 15, 2005 | 09:56 AM
Tyson's Avatar
Default Re: (atc5)
its plastic so who knows other than its going to deform a lot easier than metal. but it never will look "destroyed" or anything visible. you can feel the difference before and after tho by shaking the rack to check, thats all you need to know!
did you adjust the pinion gearbox?
Old Dec 15, 2005 | 10:08 AM
beyondspexj's Avatar
where did u get mugen motor mounts?
Old Dec 15, 2005 | 10:15 AM
atc5's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">did you adjust the pinion gearbox?</TD></TR></TABLE>
Good question, I'm not sure.
Mugen mounts and trailing arm bushings were from King Motorsports.
Old Dec 15, 2005 | 10:47 AM
crix351c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atc5 &raquo;</TD></TR><TR><TD CLASS="quote">Started monday night, here's what is done:
-rack end bushing
-metal head gasket
-dc header
-mugen motor mounts
-new lower tie rods
-new upper A arms
-ITR rear LCA's
-new timing belt
-new water pump
-new IM gasket
-honda MTF
-Motul brake fluid
-stainless lines
-ACT clutch and PP
Modified by atc5 at 3:20 PM 12/14/2005</TD></TR></TABLE>
WOW thats rare i didnt know CRX's had torsion bars
1 Fly SI
Feb 17, 2012 08:49 AM
p3anutboi
25
Oct 2, 2011 09:32 PM
89efDUSTY
Jul 10, 2009 06:47 AM
Scrapin4DR
Southeast (Sales)
Apr 21, 2009 05:53 PM
theemaddhatterr
Jul 10, 2007 06:11 AM
