h22 euro r iac wiring
Old Dec 13, 2005 | 10:00 PM
Dominic-CTR's Avatar
Default h22 euro r iac wiring
HI.
I`m installing OBD1 conversion to h22 euro R.
IAC valve has 3 wire, I know that ECU support only 2 wire..
please let me know how to re-wire ....
thanks
Old Dec 13, 2005 | 10:06 PM
98Luder's Avatar
Default Re: h22 euro r iac wiring (Dominic-CTR)
it's the same as the civic 3wire to 2 wire conversions
Katman has some pics on his FF-squad site
Old Dec 13, 2005 | 10:25 PM
Default Re: h22 euro r iac wiring (98Luder)
thanks.
That`s mean if I re-wre harness I have to buy 2 wire IAC?
Or I can use 3wire IAC like 2wire.... ?
OBD1 ECU cannot control 3 wire IAC? Correct?
Old Dec 14, 2005 | 06:21 PM
98Luder's Avatar
yea that's right you need to run the 2 pin IAC
only way i can see to run the 3pin IAC is to run an ecu that will support it.
I have seen OBD1 ecu's that run 3pin IAC's but those are not good for chipping if you plan on modifying fuel/ignition maps, who knows maybe you will find a way
good luck
hondamyheart
Aug 24, 2018 02:12 PM
three pac
Oct 22, 2010 01:53 PM
jackiewogn518
Engine Management and Tuning
Feb 27, 2010 10:54 PM
mister2racer
Jun 16, 2005 01:20 PM
ITR632
Jul 10, 2003 10:12 PM
