Rethreading a short shifter?
Old Dec 13, 2005 | 07:52 PM
97spooncivic's Avatar
Default Rethreading a short shifter?
my old short shifter snapped right where the threads end. I was wondering if i could rethread my shifter still. and if so, how?
Old Dec 15, 2005 | 09:17 AM
dognutz's Avatar
Default Re: Rethreading a short shifter? (97spooncivic)
Yes you can as I have done it. You will need a die as in tap and die. Although you may need to grind down some material if the taper gets bigger, which most do. Take your time, this should be easy if you don't rush in using the die or in grinding.
phatboy4242
Aug 21, 2007 08:08 PM
nk2k2
28
Apr 22, 2006 05:33 PM
hieu512
Mar 7, 2005 01:22 PM
