help what is the fastest way to do lowing springs!?
Old Dec 13, 2005 | 04:59 PM
RapeV-8's Avatar
Default help what is the fastest way to do lowing springs!?
i m doing the lowering springs on my crx ,but i dont want to remove the axle nut nor lower ball joints! any ideas? also on the rear suspension what is the fastest way to remove and install
Old Dec 13, 2005 | 05:04 PM
Tyson's Avatar
Default Re: help what is the fastest way to do lowing springs!? (igotcrx)
fastest way?
the correct way.
http://media.honda.co.uk/car/o...8.pdf
http://media.honda.co.uk/car/o...9.pdf
http://media.honda.co.uk/car/o...3.pdf
http://media.honda.co.uk/car/o...4.pdf
http://media.honda.co.uk/car/o...5.pdf
which does not include having to remove any balljoints or even the axle nut. who gave you that idea?
Old Dec 13, 2005 | 05:23 PM
CRX Toad's Avatar
well if you don't want to remove anything you could be dumb and heat the springs.
Old Dec 13, 2005 | 05:47 PM
RapeV-8's Avatar
well i ve always take everything apart to do the suspension! never had try any other ways to do it.
BTW: about 6 or 7 years ago i had heated springs on my car and it rides like ****!
Old Dec 13, 2005 | 06:11 PM
Crx Jimmy's Avatar
the front you dont need to take theaxle nut off or ball joint, just loosen fork and remove bolts from fork and pull off then pull shock down after removing nuts, just unbolt top nutsand bottom bolt on rear and it comes out not that hard
JDMtweezy
Honda S2000
Aug 16, 2007 11:37 AM
EGdriva
Sep 24, 2006 12:00 PM
1tz @ h0nd@ th@ng
Apr 23, 2006 01:34 PM
216.226.142.95:27016
Apr 22, 2003 08:31 AM
