2001 Accord F234A4 5-Speed coupe problem
Old Dec 13, 2005 | 04:12 PM
THE BALANCE's Avatar
Default 2001 Accord F234A4 5-Speed coupe problem
I have a 2001 f23a4 5-speed coupe problem going on here.
Around 50-60mph under acceleration ONLY my car shakes from the front.
Ive searched looking for an answer but havent had any luck.
I was thinking it might be some sort of engine hesitaion but I hope Im wrong.
Any Ideas of what it might be I could look at.
Thanks
Jimmy
Old Dec 13, 2005 | 06:32 PM
HondaTechPro's Avatar
Default Re: 2001 Accord F234A4 5-Speed coupe problem (THE BALANCE)
The most common cause of vibration under accelration is drive line. More specificly drive axles. When a CV (constant velocity) joint starts to fail it will usually cause the symptom you are describing. Unfortunately, I do not have a good way to discern whci side is causing the problem. The easiest way is to replace one drive axle at a time and see what happens.
Good Luck
sivicman
Honda Accord (2013 - 2015)
Sep 27, 2018 04:48 PM
JL_DC2
Jan 26, 2012 11:15 AM
drdavidge
24
Dec 11, 2011 07:06 PM
GGAccord
Mar 19, 2007 08:08 PM
BigBadBuford
Feb 15, 2004 08:30 AM
