92 torque converter lock up
while cruising on the highway the torque converter continually locks up and unlocks with the slightest of pedal pressure. not the usual pressure required to make a converter unlock. if you push down on the gas just a hair it will lock up and when u let up it unlock, we are talking just the slightest movement of the gas pedal. could it be the torque converter lock up solenoid and if so where is it lockated on the transmision?? Thanks for you help. come on guys give me a clue
Modified by jmleague at 12:10 PM 12/21/2005
vtec4max
May 10, 2007 12:51 PM
