Does the Use of Synthetic MTF Cause Premature Wear on the Transmission?
Old Dec 13, 2005 | 09:17 AM
CPR's Avatar
CPR
Default Does the Use of Synthetic MTF Cause Premature Wear on the Transmission?
If I recall correctly, Honda MTF is not a synthentic based oil so it makes me wonder why this is the case. After going through the archives, someone mentioned that our trannys need friction to work correctly. More specifically, the process of the synchros meshing with the gears need friction to mesh more smoothly.
Does synthetic based MTF hinder this friction?
Old Dec 13, 2005 | 09:18 AM
Dave_B's Avatar
Can someone positively clearify that MTF is synthetic or not? I was searching for this answery myself.
Old Dec 13, 2005 | 09:29 AM
Reid's Avatar
Global Moderator
Default Re: Does the Use of Synthetic MTF Cause Premature Wear on the Transmission? (CPR)
Honda MTF = non-synthetic
Honda MTF II = full synthetic
Old Dec 13, 2005 | 09:39 AM
andyt's Avatar
Default Re: Does the Use of Synthetic MTF Cause Premature Wear on the Transmission? (Reid)
If you look under the thread I created about fluids...Bbasso provided a link to another site where someone had sent the MTF off and had a compositional analysis performed....very informative!
Old Dec 13, 2005 | 09:40 AM
Dave_B's Avatar
This MTF II does anyone know if the regular stealerships carry this or is it special order?
Old Dec 13, 2005 | 11:31 AM
CPR's Avatar
CPR
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">This MTF II does anyone know if the regular stealerships carry this or is it special order?</TD></TR></TABLE>
Yeah, I want to know the same thing.
So I guess the answer is then, synthetic MTF has no ill effects on our tranny's.
Old Dec 13, 2005 | 03:40 PM
KayOs's Avatar
Available overseas only.
jaidedeye
20
Feb 24, 2013 05:35 PM
Downz
Apr 28, 2006 02:51 PM
Cimburke23
Oct 8, 2004 06:53 AM
DjFreeze
Jan 31, 2004 08:33 AM
HavokB18
20
May 29, 2003 04:16 PM
