timing belt installation
Old Dec 13, 2005 | 09:10 AM
accordcrx's Avatar
Default timing belt installation
i plan on installing a new timing belt(&water pump) in my crx hf this christmas, i've got the helms manual, i am just wondering the degree of difficulty? anyone have any tips? if i put it on wrong will it bend my valves?
Old Dec 13, 2005 | 09:20 AM
EP3_05's Avatar
Default Re: timing belt installation (accordcrx)
It can be difficult since you are doing it in such a tight space. You will have to remove the driverside motor mount to get the belts on and off. I found it difficult to put the belt on wrong if I followed the how-to in the helms manual. Just take your time and follow the instructions in the manual and you should be good to go.
Old Dec 13, 2005 | 09:41 AM
madhatter07's Avatar
Default Re: timing belt installation (91civic)
Yeha I did my T-belt for the first time over the summer, If you just follow the instructions you will be fine. Take your time though, I took from 10Am to 3AM doing it, but i liked working alone so i could go as slow as I wanted. One word of advice though, get a cank pulley bolt removal tool to save youself the headach of having to improvise. Good luck bro
Old Dec 13, 2005 | 10:01 AM
HT Chaplain's Avatar
Loved
Default Re: timing belt installation (madhatter07)
You can do, just get a impact wrench to remove cranch pulley or a special tool. just make sure you line up the arrows. Its pretty easy. Just tight space.
Old Dec 13, 2005 | 06:50 PM
1RMDave's Avatar
Yeah its pretty easy. if the crank bolt comes off easy it shouldn't take more than 1-2 hours for a first timer.
Old Dec 13, 2005 | 08:51 PM
Stunna MIKE's Avatar
Wtf.. 1-2 Hours ? I replaced a timing belt for the first time not to long ago and it took less then 30 minutes.
Old Dec 14, 2005 | 05:07 AM
1RMDave's Avatar
i'm going on the high side. Some people don't work fast. I've done mine in about 30 min. too.
Eclectia
Jan 26, 2011 11:54 AM
colnago
May 19, 2009 05:03 AM
halocore
Mar 30, 2009 09:05 PM
CivicEM1
Nov 4, 2006 08:13 PM
madman604
Feb 15, 2003 05:31 AM
