Is there supposed to be play in your axel?
Old Dec 12, 2005 | 09:29 PM
JDM H22's Avatar
Default Is there supposed to be play in your axel?
I have a h22 in my accord and I had drive shaft shop make custom axles. Well the shaft can be moved a little back and forth between the cv joints. Is that normal? I keep ripping inner boots. Any help would be appreciated. Thanks
Old Dec 14, 2005 | 11:32 AM
jdmcars.com's Avatar
Default Re: Is there supposed to be play in your axel? (JDM H22)
There should be some place. Not really more than 1/4".
If you keep having problems, and talk to drive shaft, they can normally re-make it with a slightly longer shaft -if needed.
Try to measure the amount of play with the wheels straight and the wheels loaded (meaning have the weight on the wheels), then contact driveshaft shop.
BlackLX4
Oct 12, 2016 09:33 AM
ketchup
Jun 12, 2008 05:57 AM
cycopath
Apr 23, 2008 12:11 PM
hu
Mar 24, 2007 03:16 PM
JDM H22
Dec 12, 2005 09:49 PM
