ITR suspension on dc2
OK, i searched and found that the ITR suspension should bolt right up to my 96 integra becouse of the rear LCA's are the same on the dc2R and dc2, and eg's and it would be nice if some other people could comfirm this, thanks. But my question is that will the itr suspension have a stock looking ride hight in 15 inch rims and low profile tires, or will it have a drop.
you car may have the 4x4 look with the low pro tires. oem itr suspension aint that much different drop wise. Still got that oem tire gap no matter what. think about it.
rear LCA on 94-01 GSR, GS, LS, RS, SE are DIFFERENT then Type R's.
If you want to use ITR specific shocks, all you need to do is replace the non Type R rear lower control arm with a Type R one.
If you put ITR suspension on your car, your ride height will look like a stock Type R which also has 15" tires. It will lower then a stock/non R integra.
And for tire size, stick to 195/55 or 205/50. 195/50 will leave more wheel gap
bacardiboi
Jul 23, 2007 09:59 PM
