will b16 tranny shift forks, swap from cable to hydro?
hey guys, 5th gear and reverse are out(wont go into gear at all) in my hydro b16a tranny.(dont know exactly the tranny code). but i bought a cable tranny for $150, so i figured i might be able to swap shift forks from the cable tranny to the hydro tranny(just the 5th gear and reverse). will this work? Also, if that does work is there anything else i can take out of the cable tranny and put in the hydro?(like the final or any gears that are better) thank you guys. PLEASE HELP!!!
I also have a related question. Are all b series shift forks the same? I'm looking to put hydro b16 forks in a jdm itr trans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone »</TD></TR><TR><TD CLASS="quote">no it will not work, shift forks are different.
hydro to hydro will work in most case's
</TD></TR></TABLE>untrue. 92-93 cabloe trannies use the same shift forks as hydro trannies. they use 3 seperate shift forks. 90-91 cable boxes use a 2 shaft single piece unit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therealpoorboy »</TD></TR><TR><TD CLASS="quote">untrue. 92-93 cabloe trannies use the same shift forks as hydro trannies. they use 3 seperate shift forks. 90-91 cable boxes use a 2 shaft single piece unit.</TD></TR></TABLE>
you are correct and I should have been more specific, sorry. I was assuming he had a 90-91 and did not think of the 92-93. good looking out.
Justef Datshiet
Jan 11, 2013 04:13 PM
mrjdm2u
Dec 12, 2005 08:48 PM
