tires, which one(yokohama,sumitomo)
Old Dec 12, 2005 | 07:44 PM
snowman0520's Avatar
Default tires, which one(yokohama,sumitomo)
i plan on staying in stock class next year for autox. im downsizing to 13S and need tires. Ive narrowed it down to 2 that im interested in. these are going on vx rims.im leaning more towards the yokohama's right now. both get about the same ratings from tirerack.
btw:these will only be used for autox so im not worried about wet traction and all.
http://www.tirerack.com/tires/...ace=7
http://www.tirerack.com/tires/...R+200
if u know of any other good tires that will fir these rims feel free to tell
Old Dec 14, 2005 | 10:39 PM
bmoua's Avatar
are those any good for autocross...???i'd go with something better....
Old Dec 15, 2005 | 09:06 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (bmoua)
Out of those the yoko is a nicer tire from what I've seen.
My dad has a set for his crx. Hes quite happy.
Old Dec 15, 2005 | 09:28 AM
thanxs for replys. i actualy found another tire. yoko ADVAN A032R
Old Dec 15, 2005 | 09:38 AM
old man neri's Avatar
Default Re: (Ace$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">are those any good for autocross...???i'd go with something better....</TD></TR></TABLE>
not too much out there in the 13 size
I myself have the Sumis on my car for street use. I have no complaints about them but I have nothing to compare them too. Sumis has the advantage they offer a lot of aspect sizes in the 13in size.
Old Dec 17, 2005 | 02:41 PM
Turbo240's Avatar
you have made a much better choice going with the A032rs for auto-x only
Old Jan 19, 2006 | 08:50 AM
Clay@tirerack's Avatar
Honda-Tech Sponsor
Default Re: (Turbo240)
The A032R is the race compound tire so it will be much better suited for what you are looking for.
Old Jan 23, 2006 | 07:19 AM
Mike_C's Avatar
the first two you listed are basically all season tires... i actually use the avids for driving my track car to the track the a032r is a no brainer, it actually has grip.
Old Jan 23, 2006 | 07:42 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Mike C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">the first two you listed are basically all season tires...</TD></TR></TABLE>
The Yokohama Avid T-4 is indeed an all-season tire. However, the Sumitomo HTR 200 is a crappy summer tire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">the a032r is a no brainer, it actually has grip.</TD></TR></TABLE>
Absolutely. Since you're only using them for autocross, get the A032R.
Old Jan 23, 2006 | 10:09 AM
im just debating if the 175 will have as much traction or more than my 195 falken azenis 512. acording to yokohama's website i cant fit 205s on a 5 inch rim
Old Jan 23, 2006 | 12:35 PM
Mike_C's Avatar
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The Yokohama Avid T-4 is indeed an all-season tire. However, the Sumitomo HTR 200 is a crappy summer tire.</TD></TR></TABLE>
basically an all-season. the t4 probably has more grip
Old Jan 23, 2006 | 12:53 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (snowman0520)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowman0520 &raquo;</TD></TR><TR><TD CLASS="quote">im just debating if the 175 will have as much traction or more than my 195 falken azenis 512. acording to yokohama's website i cant fit 205s on a 5 inch rim</TD></TR></TABLE>
I'm not sure I understand the question. You are wondering whether the Yokohama Avid T-4 or the Sumitomo HTR 200, in 175/70-13, will have as much traction as a Falken tire? But which Falken tire do you mean when you say the "azenis 512" - the Falken Azenis RT-215, or the Falken Ziex ZE-512? (It sounds like you were using one of those two tires in 195/50-15...?)
All of these tires offer really crappy performance for autocross: Yokohama Avid T-4, Sumitomo HTR 200, and Falken Ziex ZE-512.
Both of these tires offer excellent performance for autocross: Falken Azenis RT-215, and Yokohama A032R.
The size (195 vs 175) won't change either of these two statements.
Does that answer your question? Or are you trying to figure out which crappy tire offers better traction than which other crappy tire? If so, don't bother...
Old Jan 23, 2006 | 07:38 PM
right now i have 195/60-14 falken ziex-512 which i autocross with. i need to down size to 13"x5" rims for H-stock and yokohama only offers 175/60HR13 for the ADVAN A032R that will fit that rim, so i am hopping that i will get better traction out of the yoko even tough they are 175 wide.
Old Jan 23, 2006 | 09:09 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowman0520 &raquo;</TD></TR><TR><TD CLASS="quote">right now i have 195/60-14 falken ziex-512 which i autocross with. i need to down size to 13"x5" rims for H-stock and yokohama only offers 175/60HR13 for the ADVAN A032R that will fit that rim, so i am hopping that i will get better traction out of the yoko even tough they are 175 wide. </TD></TR></TABLE>
Oh, yes. You will get much much MUCH better traction from a track tire that is 20 mm narrower, than from a crappy all-season tire that is 20 mm wider. No comparison whatsoever.
You also might try the 215/50-13 size A032R; I know they're a lot wider but since they're smaller in diameter, they might not rub and the extra width might be fine for autocross purposes. (The 215/50-13 is 5.2 percent smaller in diameter than 175/70-13, which I assume is your stock size, and 175/60-13 is even smaller, 6.1 percent smaller in diameter than stock.)
Another possibility is the Hoosier A3S05 tire, which is designed specifically for autocross. (It won't need much warmup the way the A032R would.) It comes in 225/45-13. Again, it might not rub because, even though it is a whole lot wider than stock, it's also 7.4 percent smaller in diameter.
Check to see what the top finishers in your class in autocross are using on their cars. You might also seek advice in the Road Racing/Autocross forum here on h-t.com
Modified by nsxtasy at 12:27 AM 1/24/2006
Old Jan 24, 2006 | 05:15 AM
im actualy the top finisher in my class right now, but ill check other classes. i highly dought ill be able to fit the 215s on a 5 inch rim tough. autox class: H-Stock
Old Jan 24, 2006 | 06:43 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowman0520 &raquo;</TD></TR><TR><TD CLASS="quote">im actualy the top finisher in my class right now, but ill check other classes.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowman0520 &raquo;</TD></TR><TR><TD CLASS="quote">i highly dought ill be able to fit the 215s on a 5 inch rim tough.</TD></TR></TABLE>
Oops! Good point.
Here are the ranges of approved rim widths for the above tires:
Yokohama A032R 175/60-13 - 5.0-6.0 inches
Yokohama A032R 215/50-13 - 6.0-7.5 inches
Hoosier A3S05 225/45-13 - 8.0-9.0 inches
So you're right; if you have to use that rim width, you can't use the wider sizes I mentioned. Sorry!
Old Jan 24, 2006 | 11:07 PM
ispep's Avatar
205/60's are a good fit on a vx wheel. They were very easy to mount. I've got the HTR 200's on there right now, and I have a set of 205 advan a048's waiting for my second set of vx wheels to get painted.
Modified by ispep at 12:32 AM 1/25/2006
Modified by ispep at 12:42 AM 1/25/2006
Old Jan 25, 2006 | 07:01 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (ispep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ispep &raquo;</TD></TR><TR><TD CLASS="quote">I have a set of 205 advan a048's waiting for my second set of vx wheels to get painted.</TD></TR></TABLE>
You must have gotten them from a company that imported them from abroad. Yokohama is not marketing any sizes smaller than 15" in North America, so you can't get them from most Yokohama dealers (e.g. Tire Rack) and they won't be warrantied by Yokohama. Not that that should be a show-stopper, by any means; a size 205/60-13 Yokohama A048 (their R compound track tire that is replacing the A032R in their lineup) would be PERFECT for autocrossing on 13" wheels on a Civic. If you can find a place that sells them, go for it!
Old Feb 16, 2006 | 08:32 PM
Sequoyah's Avatar
I found these at tire rack...
http://www.tirerack.com/tires/...ace=1
I talked to someone tonight about buying some VX wheels...he told me originally that they were HX wheels, but they weren't. I wasn't sure if I wanted them or not because I didn't know anything about what the selection of tires was like in a 13. I think I may buy them tomorrow...can't go wrong for $100 w/ tires
Old Feb 17, 2006 | 05:14 AM
those came out to $500 shipped and heat cycled. it was just too much for me so i went with the somitomo htr 200. i wish i would of gone with the r compound but it was just too much
Old Feb 17, 2006 | 06:53 AM
Sequoyah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowman0520 &raquo;</TD></TR><TR><TD CLASS="quote">those came out to $500 shipped and heat cycled. it was just too much for me so i went with the somitomo htr 200. i wish i would of gone with the r compound but it was just too much </TD></TR></TABLE>
I was talking about the VX wheels The Yokohamas are pretty expensive...I figure for the first season of taking my car out, I'll start off with a more affordable tire too.
Old Feb 28, 2006 | 07:38 AM
hybridmoments's Avatar
you are first in your class with crappy all season tires , running against cars using R compound tires?
wow. you must be an amazing driver. would be kinda embarrassing being beat by someone with allseasons. R compounds can easily give you 2-3 seconds over all seasons. most people say 2 seconds or more switching from Azenis to R compounds if i remember correctly.
Nader_D
Feb 1, 2004 11:35 PM
98silverex
Sep 13, 2003 07:39 PM
SleeprCivic
Jul 19, 2003 06:21 PM
Petah
Sep 17, 2001 01:45 PM
Petah
Sep 17, 2001 09:44 AM
