'91 Accord Idle problem
Old Dec 12, 2005 | 06:07 PM
v_dub_ya's Avatar
Default '91 Accord Idle problem
Hello, found your site from a friend at http://www.tremek.com.
I have a 1991 Accord EX 2.2L that recently started idling abnormaly. Wife told me that when she cranks the car up in the morning, it idles up and down after runnin for a few minutes. I started her car this morning and after about 3 minutes of warm-up, i hit the brake to take it out of Park and it started idling up and down, close to 2000 and back down to 1000. Does this vehicle have an IAC(Idle air control) valve or does this sound like a possible vacuum problem? Idle is better after car is upto operating temperature.
Any help will be greatly appreciated
Thanks
v_dub_ya
Old Dec 12, 2005 | 06:57 PM
Nick H's Avatar
New User
Default Re: '91 Accord Idle problem (v_dub_ya)
yes...sounds like a problem with the iacv to me...it is located either under the intake manifold plenum or on the back of the intake manifold near the throttle body (sorry, it's been a while since i've had an f22 in my accord)...try replacing the screen first...if that doesnt work, you may need to replace the iacv all together...hope that gets you started in the right direction...
Old Dec 12, 2005 | 07:06 PM
v_dub_ya's Avatar
Default Re: '91 Accord Idle problem (Nick H)
thank you for a starting place, ill let you know how it turns out
thanks again
v_dub_ya
Old Dec 12, 2005 | 08:33 PM
hondaguy6513's Avatar
Also consider the fast idle thermo valve, I have seen them cause irratic idle problems in 4g's. (if they are not getting coolant.)
BuiltF22
Sep 12, 2015 01:58 PM
nrmskate
Sep 10, 2013 08:28 AM
desertratt
Sep 15, 2011 11:35 PM
ajth87
Mar 9, 2006 01:49 PM
95ACEX
Mar 9, 2004 08:41 AM
