BRAND NEW Civic and Integra Turbo Kit I have Both B Series and D Series $700
Old Dec 12, 2005 | 05:51 PM
wushubrian's Avatar
Default BRAND NEW Civic and Integra Turbo Kit I have Both B Series and D Series $700
This is a complete turbo kit that I pieced together from the best of parts from different companies to make a turbo kit that I was going to use on my 98 honda civic with an integra ls(b18b) engine. Though this will fit any b(dohc) series or d(sohc) engines because it does not have the exhaust manifold. This is the only part that you need to change for the different types of engines. The kit has everything else and everything is brand new and has never been used.
The kit includes:
Complete charge piping set. This is also known as intercooler piping. Also includes the intake piping. This is Mandrel-bent Aluminum Polished 2.5" piping. Its also rolled at the ends to prevent blowoff. Includes Clamps , Rubber heat and pressure tested reducers and couplers. Also brass fittings are included.
Greddy Intercooler. This intercooler is the thick design one and is 4 inches thick. Its also 27 inches wide and 8 inches tall.
T3 turbo with GARRETT INTERNALS. This turbo has wet floating bearings. The turbine housing a/r is .48 and the compressor housing ratio a/r is .42. It is oil cooled and has a standard flange.
Tial 35 mm wastegate. This wastegate can be adjusted from 3.63 Psi TO 19 Psi. Comes with an adjustable spring. Also 38 mm to 35 mm wastegate adapter. All Gaskets, Flanges, Accessories are included.
RFL Blow off valve made by xs power. This is an RFL style blow off valve. The spring inside is just ride and will make a loud bov sound.
Turbo steel braided oil line kit. Comes with a lot of different size oil lines to connect to a turbo and also to drain the oil.
vacuum tee's and vacuum lines are included as well.
All clamps, bolts, fittings, and gaskets are included.
I have run into financial problems and that is why I am selling it. Once again the only part you need is the exhaust manifold. All equipment is brand new. If you have any questions please fell free to contact me.
THIS IS FOR SALE ON EBAY FOR $700
http://cgi.ebay.com/ebaymotors...&rd=1
Old Dec 13, 2005 | 04:48 AM
wushubrian's Avatar
Default Re: BRAND NEW Civic and Integra Turbo Kit I have Both B Series and D Series $700 (wushubrian)
BUMP...
Old Dec 13, 2005 | 10:23 AM
wushubrian's Avatar
afternoon bump.
Old Dec 16, 2005 | 12:57 PM
wushubrian's Avatar
ttt
Old Dec 17, 2005 | 09:54 AM
wushubrian's Avatar
up we go.
jdoc325
Northeast (Sales)
Jul 7, 2016 07:11 AM
bebfsu1
Feb 7, 2006 01:10 AM
wushubrian
Dec 17, 2005 12:24 AM
wushubrian
Dec 10, 2005 12:47 PM
[626]95-GSR
Aug 8, 2002 09:16 PM
