3 angle valve job Vs. multi angle valve job
I was wondering the difference between the two IN PERFORMANCE. My setup i'm shooting for is 220+ whp and 150+ wtq. Is there a big difference IN PERFORMANCE. between a 3 or 5 angle valve job?
Modified by kidd_drastic at 5:04 PM 12/12/2005
At its most basic level....the more angles a valve job has the better the seating for the valve. More angles = less obstruction for the fuel/air charge when it enters the head also. I'm sure one of the guru's can go into greater detail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey »</TD></TR><TR><TD CLASS="quote">omg, Don is comedy sometimes....im sorry i shouldnt be laughin but its funny. First laugh ive had all day ( i needed it i hate my car
)</TD></TR></TABLE>
what happened?
)</TD></TR></TABLE>what happened?
The correct answer is: there is no correct answer. Different porters get different results with different valve jobs. One kind is not universally better with every port.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">Basics:
Radius > angle.
Stock valve job = stock flow, for the most part.</TD></TR></TABLE>
Radius > angle.
wouldn't something like a mira-cut (5 angle) job help increase the overall flow out of the port since there are more angles? The increase in angles supposedly allows a more gradual transition from the port to the combustion chamber while still allowing the valves to seat. The same goes for the angles on the valve, though i think most folks stick to 3 angles on the valve.
I don't do much head work, so I'm not really sure. Any insight?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidd_drastic »</TD></TR><TR><TD CLASS="quote">i'm lost. why would i want stock air flow?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZhaGg »</TD></TR><TR><TD CLASS="quote">wouldn't something like a mira-cut (5 angle) job help increase the overall flow out of the port since there are more angles? The increase in angles supposedly allows a more gradual transition from the port to the combustion chamber while still allowing the valves to seat. The same goes for the angles on the valve, though i think most folks stick to 3 angles on the valve.
I don't do much head work, so I'm not really sure. Any insight? </TD></TR></TABLE>
as stated before, a full-radius valve job done on a Serdi machine is best
In theory should help but no enough to see huge gains in reality. 3 angle and some slight oversized valves. All my heads get a 3 angle valve job.
