Setting the timing on Engine. Jumping the SCS connector...?
Old Dec 12, 2005 | 02:57 PM
P@@RB@Y's Avatar
Default Setting the timing on Engine. Jumping the SCS connector...?
When jumping the SCS connector with a paper clip should the car be off or idleing at 750 + RPM?
Old Dec 12, 2005 | 03:05 PM
520_Motorsports's Avatar
Default Re: Setting the timing on Engine. Jumping the SCS connector...? (P@@RB@Y)
I does not matter if you are jumping to look for codes it will give them either way.
P@@RB@Y's Avatar
Also does the cars fan really havr to come on or just be a operating temp.?
Old Dec 12, 2005 | 03:07 PM
P@@RB@Y's Avatar
Default Re: Setting the timing on Engine. Jumping the SCS connector...? (SlowAzEg)
Not looking for codes, Im setting the timing.So its safe to jump the SCS with a paperclip with the engine running?
Old Dec 12, 2005 | 03:16 PM
CRXified's Avatar
i dont think it matters, i did it when the car was off then started it
Old Dec 12, 2005 | 03:17 PM
P@@RB@Y's Avatar
Bump
Old Dec 12, 2005 | 03:34 PM
EG6H22PWRD's Avatar
Yo dawg it dont matter if you use the paper clip method while you doing your timing. Make sure you do the proper way to time your engine. Either access panel for the flywheel, or the pulley (spinner for me since mines cromed out!). oh and make sure the cel light is on if you want some codes!!!
Old Dec 12, 2005 | 03:56 PM
anony95ex's Avatar
Jump it while it's idling, and use a timing light to check the marks.
LostGsr
Aug 4, 2011 04:08 AM
royalfelix
Feb 20, 2008 06:23 PM
garyc17
Feb 4, 2008 02:18 AM
90teg
Aug 26, 2003 01:45 AM
