Vacuum hose routing diagram for a 1985 honda CRX
Hey guys as the name says i need a vacuum hose routing diagram for a 1985 honda crx it seems that the one on the hood of the car is missing and i have not been able to find one...... if any of you could help that would be awesome...
Thanks in advanced
Thanks in advanced
there is only like 2 or 3 hoses that you need. u can take all of em off and just get a vac plug kit to plug the 3 big vac lines off the manifold. just make sure that you leave the vac advance hooked up and the charcol can and electrical load sense to distributer also hooked up but other than that oh the on that goes to the "3rd" barrel on the carb need to be hooked up also.
Its the ones that come of the charcol can that i need to know where they go... to be more specific the purge line off the canister is unpluged and i need to know where to plug it in... if anyone knows that would be great. (where abouts on the carb it plugs into is what i need)
Now here is another silly question for you guys where is the purge cutt off solenoid valve located on on the engine/carb.... i have no idea.....
Thanks for all the help its been great in getting the problem solved..
crxb18a1
Mar 1, 2005 12:45 PM
