92-95 HEADER QUESTIONS
Old Dec 12, 2005 | 12:44 PM
djrock04's Avatar
Default 92-95 HEADER QUESTIONS
is there any difference in headers of the different civic versions as in cx ex dx etc i have a 1994 sohc 1.5 hb i need a new header i want an aftermarket one
Old Dec 12, 2005 | 01:23 PM
ShadyBAB's Avatar
Default Re: 92-95 HEADER QUESTIONS (djrock04)
Don't think so
Old Dec 12, 2005 | 02:02 PM
JimmyAtlantis's Avatar
Default Re: 92-95 HEADER QUESTIONS (ShadyBAB)
yes...I can tell you for a fact that the 94 EX and DX are completely different.
Old Dec 12, 2005 | 04:18 PM
transpar_nt's Avatar
Default Re: 92-95 HEADER QUESTIONS (JimmyAtlantis)
...and the cx has the cat on the header, so its different too.
EDIT: if you're getting an aftermarket one it won't matter.
Old Dec 12, 2005 | 04:34 PM
boostedcivicsmith's Avatar
Default Re: 92-95 HEADER QUESTIONS (transpar_nt)
96-00 cx and dx have a catalytic converter on header. Otherwise the rest are the same.
Old Dec 12, 2005 | 04:38 PM
JamesV's Avatar
my 93 cx doesnt have a cat { all i see is header and pipes }
so if i get a dc 4-2-1 2pc header.. will i have to buy a cat converter?
Old Dec 12, 2005 | 04:48 PM
bigwhitebucket's Avatar
Default Re: (JamesV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JamesV &raquo;</TD></TR><TR><TD CLASS="quote">my 93 cx doesnt have a cat { all i see is header and pipes }
so if i get a dc 4-2-1 2pc header..</TD></TR></TABLE>
It's there, it's behind a heat shield on your exh. mani
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JamesV &raquo;</TD></TR><TR><TD CLASS="quote"> will i have to buy a cat converter?</TD></TR></TABLE>
If you wanna renue your tags you do.
Old Dec 12, 2005 | 05:12 PM
Default Re: (bigwhitebucket)
Here in Canada '94 and older vehicles don't need cats
Old Dec 12, 2005 | 06:05 PM
jlsmi2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djrock04 &raquo;</TD></TR><TR><TD CLASS="quote">is there any difference in headers of the different civic versions as in cx ex dx etc i have a 1994 sohc 1.5 hb i need a new header i want an aftermarket one</TD></TR></TABLE>
Yes. In factory form the vx and cx have a catalytic converter that comes directly off (connected to) the manifold. The dx, lx and ex have an exhaust manifold and then a separate catalytic converter directly in line with the cat back exhaust.
Unless you really NEED a new header you might as well just leave the factory manifold on. You will see little to no improvements in power in swapping the header on the 1.5L.
Good luck.
Old Dec 12, 2005 | 07:15 PM
siregcivic's Avatar
Default Re: 92-95 HEADER QUESTIONS (jlsmi2)
u dont need a cat u just need a trusted known smog tech. hahaha yah i love it
Old Dec 12, 2005 | 07:55 PM
JamesV's Avatar
hmm yeah tag re-new in may.. ill just wait
Old Dec 12, 2005 | 07:56 PM
JDM-EJ1's Avatar
Default Re: 92-95 HEADER QUESTIONS (boostedcivicsmith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsmith &raquo;</TD></TR><TR><TD CLASS="quote">96-00 cx and dx have a catalytic converter on header. Otherwise the rest are the same. </TD></TR></TABLE>
Old Dec 13, 2005 | 01:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlsmi2 &raquo;</TD></TR><TR><TD CLASS="quote">Unless you really NEED a new header you might as well just leave the factory manifold on. You will see little to no improvements in power in swapping the header on the 1.5L.
Good luck. </TD></TR></TABLE>
His enigne could breathe so much easier if he put a z6 exhaust manifold on his d15. That d15 header sucks.
Old Dec 13, 2005 | 01:37 AM
His enigne could breathe so much easier if he put a z6 exhaust manifold on his d15. That d15 manifold sucks.
Old Dec 13, 2005 | 05:09 AM
Everyones Hero's Avatar
If you decide to get a header you can always do the entire exhaust.
Get a header and catback designed for an EX.
That way you get the header like you want, and you get a new exhaust system w/ cat that will bolt right up.
Old Dec 13, 2005 | 05:14 AM
Default Re: 92-95 HEADER QUESTIONS (Everyones Hero)
If there is nothing done to the engine and if you don't plan on doing anything to the engine I wouldn't go any bigger than 2"-2.25" on the exhaust.
Old Dec 13, 2005 | 09:26 AM
djrock04's Avatar
what is a z6 mainfold???
Old Dec 13, 2005 | 09:31 AM
djrock04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimmyAtlantis &raquo;</TD></TR><TR><TD CLASS="quote">
His enigne could breathe so much easier if he put a z6 exhaust manifold on his d15. That d15 header sucks.</TD></TR></TABLE>
z6? whats that? amd i have a new cat in the middle of the exhaust system i want to get just a cat back exhaust and the header but i need ti know what kind of header i should get for my 1994 cx 1.5 hb
Old Dec 13, 2005 | 09:41 AM
z6 being the d16z6 engine. You need to get a catalytic converter as well if you plan on doing a full exhaust. It would go header---&gt;cat converter---&gt;cat back exhaust. You can get any header that says it will fit a d-whatever engine. I wouldn't recommend going over 2"-2.25" on the cat back. Get a cat converter for a dx/ex/si.
Does anybody have anything to add or any corrections to make?
Old Dec 13, 2005 | 09:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimmyAtlantis &raquo;</TD></TR><TR><TD CLASS="quote">Does anybody have anything to add or any corrections to make?</TD></TR></TABLE>
I would just get an exhaust system made for a 92-95 Si Hatchback, along with a header for either an Si HB or an EX coupe.
If he gets a full catback for a Si Hatch he will get a new undercar cat with his exhaust system, and the header for the Si Hatch or EX coupe will bolt right up to the motor and to the new cat that comes with his exhaust system.
Old Dec 13, 2005 | 09:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">I would just get an exhaust system made for a 92-95 Si Hatchback, along with a header for either an Si HB or an EX coupe.
If he gets a full catback for a Si Hatch he will get a new undercar cat with his exhaust system, and the header for the Si Hatch or EX coupe will bolt right up to the motor and to the new cat that comes with his exhaust system.</TD></TR></TABLE>
catbacks don't come with the converter.
Old Dec 13, 2005 | 10:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimmyAtlantis &raquo;</TD></TR><TR><TD CLASS="quote">catbacks don't come with the converter.</TD></TR></TABLE>
My mistake. I was under the impression they did.
I bought mine used and the guy told me that he sold the cat that came with it.
Old Dec 13, 2005 | 02:31 PM
djrock04's Avatar
z6? whats that? amd i have a new cat in the middle of the exhaust system i want to get just a cat back exhaust and the header but i need ti know what kind of header i should get for my 1994 cx 1.5 hb</TD></TR></TABLE>
all i want to is change the exhaust manifold and get a cat back exhuast dont wanna do the whole thing
Old Dec 13, 2005 | 04:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djrock04 &raquo;</TD></TR><TR><TD CLASS="quote">all i want to is change the exhaust manifold and get a cat back exhuast dont wanna do the whole thing</TD></TR></TABLE>
You have to. Can anybody else explain this any straighter than I did? I though I did a good job.
Old Dec 13, 2005 | 07:12 PM
Getting a header and catback exhaust is pretty much changing the whole thing. Only thing left for you to pick up would be a cat, which you can get a high-flow fairly cheaply.
