Blox Cams....????
Old Dec 12, 2005 | 10:53 AM
BEEYOND's Avatar
Default Blox Cams....????
I am using a JUN3 cam that made about 195whp on a LS/VTEC. Blox's HSL claimed to make just as much or more power then the JUN3..so I bought a set, but never put them in to try the difference.. WHAT do you guys think???
I may not use them so if anyone wants it let me know.. PM me asap.. I will give them up for CHEAP... I also have the Blox valve train to go with it... Remember ALL BRAND NEW STILL int he box...
Old Dec 12, 2005 | 12:33 PM
fmrprojects's Avatar
Default Re: Blox Cams....???? (lsvtecpower)
I'd slap those babies in and see what kinda power they make. I'm running the blox type b's and im making 217hp 139tq. so i'm pretty sure they can make you more power. the hsl cams are better than the type b's for sure. Keep us posted, good luck
Old Feb 15, 2006 | 10:43 AM
drintegra's Avatar
Default Re: Blox Cams....???? (fmrprojects)
What is ur set up running that much HP. I am curious as I am trying to develop a build and want experience with the Blox B's. I am about to put them on gsr 4 now.
Back to the post, seems like your set up would work well with the Blox B cams, so give it a try and post a Dyno to compare.
Good Luck
Old Feb 15, 2006 | 11:34 AM
Ruben19's Avatar
IM LOOKING FOR THOSE CAMS RETAINES AND SPRINGS
LET ME KNOW HOW MUCH YOU WANT IF YOU DECIDE TO SELL THEM
Old Feb 15, 2006 | 11:37 AM
acydphryck's Avatar
Default Re: Blox Cams....???? (BEEYOND)
I'm using the Blox B's right now (much thanks Skinhead )...they work great...don't know much about the HSL's though...did you try and do a search on here for those cams yet??
Old Feb 15, 2006 | 11:58 AM
dohcMONSTER's Avatar
Default Re: Blox Cams....???? (acydphryck)
im using the comp. HSL's and i <U>love them</U> they pull like holy hell after 6500. are you going to use the competition or tuner HSL's?
Old Feb 15, 2006 | 12:40 PM
UncleD's Avatar
Default Re: Blox Cams....???? (dohcMONSTER)
Blox HSL's and S2S3's are the same thing.
Old Feb 15, 2006 | 01:00 PM
Default Re: Blox Cams....???? (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Blox HSL's and S2S3's are the same thing.</TD></TR></TABLE>
the tuner HSL's are, but im using the Comp. HSL's which have bigger primaries
Old Feb 15, 2006 | 03:29 PM
broketuner-Sol_Si's Avatar
I haven't heard too much about the HSL cams, but about blox in general I've heard the competition series is better than the tuner series. I'd throw them in there and see how they do. If all else fails you can just sell them with only a couple of dyno passes on them(I'd buy them if you don't like them, if they are the comp. series).
Old Feb 21, 2006 | 10:08 PM
xyzalvarez's Avatar
Default Re: Blox Cams....???? (drintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drintegra &raquo;</TD></TR><TR><TD CLASS="quote">What is ur set up running that much HP.
Old Feb 21, 2006 | 10:25 PM
UncleD's Avatar
Default Re: Blox Cams....???? (xyzalvarez)
I'll bet $$ that the "tuner series" is the same as the staged S2 cams, and the "comp" series is the same as the Pro series S2 cams.
koczeka
11
Oct 14, 2006 07:27 PM
VtecDA9
105
Jan 27, 2006 05:35 AM
JMcDB18C
Apr 22, 2005 10:39 PM
just4fun
Sep 10, 2002 12:09 PM
fast[R]
May 28, 2002 02:35 PM
