s20 transmission inspection plate.
Does anyone have a picture of the inspection plate being mounted on to the tranmission. I don't have one, and I'm curious to see how it mounts up and what not. Thanks.
I dont have a pic but I can get one from my shop manual later if you want.
There are two studs on the oil pan rather then bolts, take the nuts off of those, and hold the plate up there and put them back on. Now there are two short bolts that hold the bottem of the plate against the transmission.
Pretty simple really.
I would appreciate it if you could post up a picture. Now, since it looks like we use an oil pan for support in this situation, is there such a thing as an 'automatic' and 'manual' transmission oil pan?
Did the automatic transmission have an inspection plate even?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">Yep it also has an inspection cover, Ill get you a pic of the manual trans its easier to see.</TD></TR></TABLE>
Right on. Thanks man.
mesrop1991
12
May 28, 2015 08:37 AM
baphomet
Dec 19, 2005 01:41 PM
tek_civic
Aug 14, 2003 02:13 PM
del, ej1, fluid, honda, inspection, jdm, manual, oil, plate, recommended, s20, seal, sol, transmission, trasmision
