Where to buy oversized h22 (type-s) piston rings...???
Like the title states... I cant seem to find anyone that carries these rings.
The OEM rings are expensive as hell... anyone have some suggestions for me?
Also, I've had some confusions with what size the pistons actually are... they are ".25 over" so wouldnt that make them 87.25?
Thanks for the help.
I've been told that although the pistons are stamed "25" that they are actuall 10 over pistons... can anyone verify this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">For the H-series, usless you have sleeved the block, use factory rings. Also read the Helms as to what one goes where, 1st and 2nd ring.</TD></TR></TABLE>
Can you explain why I should only use factory rings?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PocketRockets Racing »</TD></TR><TR><TD CLASS="quote">0.25mm is 0.010"....give or take </TD></TR></TABLE>
Alright thanks for the clarification.
So what rings exactly should I be looking for?
Just use OEM H22 oversize rings from a stealership or an online parts place. They will work fine with the FRM cylinders.
pm me, i can check with Hastings to see if they got exactly what you need. Hastings are great product to go with as well. Far better then OEM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 »</TD></TR><TR><TD CLASS="quote">pm me, i can check with Hastings to see if they got exactly what you need. Hastings are great product to go with as well. Far better then OEM </TD></TR></TABLE>
we had a brand new set of hastings that were way too loose straight out the box, had to goto the dealership the next day for a set of stock rings.
imo if you can use stock rings, use it. i'd only go aftermarket if i overbored too far
