B18a Swap into 91 civic...alternator & starter?
i was planning on getting these new anyway but do i buy them for a 91 civic or a 90 integra? will the alternator bolt onto the back of the block in its original position? thanks
Get them for the LS (B18) the starter is different.
I have both of them used just sitting if you need one cheap.
in that case i have them cause they came with my swap. okay so i can use the alternator and starter from the teg? will they be wired differently?
I highly doubt they will be wired differently. The starter is just two connectors, which it should be the same, and the alternator is more than likely interchangable between b and d series.
DriftStaRSi91
14
Jun 19, 2011 11:55 AM
