ECU has no power. car turns over but ecu no flashy HELP
i have a 88 hf crx and i was recently working on it...i shorted out the map sensor to a power block coming from battry, car cut off and wouldnt start. the ecu doesnt flash when i turn the key on, fuel pump not coming on.
i tried a new pm6 but it does the same. could it be main relay? i tested the ground circuit and its good...no power to ECu
Helpp please.
Helpp please.
yea... i pulled the main relay and tested it. one test i did the resistance was jumping around alot and it was the ecu port. im gonna try a new relay
AndyDaSilva
Jun 27, 2015 09:01 AM
2 0 3
Jul 30, 2006 05:36 PM
