important heat question
My heater doesnt work on my accord. The AC works but the heater doesnt. it is like regular fan air comming through. please tell me what could be the problem.
There is a cable controlled Hot Water Control Valve mounted to the firewall (Engine side) which could either be frozen shut or the control cable could be disconnected or broken.
You're going to have to eyeball it to confirm the lever moves whenever the heater control is worked.
P
Modified by P_Adams at 1:07 PM 12/12/2005
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">You're going to have to eyeball it to confirm the lever moves whenever the heater control is worked.</TD></TR></TABLE>And since he didn't say what year, we can't tell him whether his key needs to be turned on while checking...
first, is your cooling system leaking? if not you could have an open tstat causing the car to put out little or no heat. if the water valve is working this is what I would check
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollercosta123 »</TD></TR><TR><TD CLASS="quote">i have a 97 accord ex</TD></TR></TABLE>On my '98 the heater valve is motor-driven, so it doesn't move unless the key is turned on. I'm not sure whether your 5th-gen is the same way.
If these are not the problem, check under the dash on the right side of the console where the carpet meets the firewall and find the lever that the temp control **** is actuating and make sure it is fully closing the air mixture door when you switch to heat.
[QUOTE=P_Adams]There is a cable controlled Hot Water Control Valve mounted to the firewall (Engine side) which could either be frozen shut or the control cable could be disconnected or broken.
I repeat my first responce........
P
P
cheyennerex
Apr 21, 2003 02:56 PM
