Can you use z6 Distributor on a y8 head.....?
Old Dec 11, 2005 | 10:16 PM
Eman919's Avatar
Default Can you use z6 Distributor on a y8 head.....?
I was wondering if anyone can tell me if It's okay to use a d16z6 distributor on a d16y8 head. I'm running a ZC block w/ a d16z6 vtec head (OBD1, P28 ECU) and im putting a y8 head now....so does anyone know if i can use the same z6 distributor? And also, which head gasket should i use? (zc or d16y8)......THANKS ANYONE......
Old Dec 13, 2005 | 02:52 PM
minimesleeper94's Avatar
the dizzy's should swap. check out http://www.d-series.org you will deffinately find your answers there. as far as head gaskets, if your using sohc head then you prolly have a sohc zc block. use the z6/y8 head gasket. they're both the same 3-layer metal head gasket.
jewpont
10
Oct 12, 2008 03:49 PM
92superhb
May 2, 2006 05:28 PM
mugenwannabe
Apr 17, 2004 01:25 PM
CRXSiR71777
Feb 29, 2004 09:25 PM
