Flywheel Vs. Wheel
Old Mar 15, 2002 | 03:19 PM
KooK's Avatar
Mustang Sally
Default Flywheel Vs. Wheel
Ok, so you lose some horsepower from the flywheel to the wheels? Where do you lose it at (what takes it away) or is it just measured differently? Is there anyway to get some of it back? And when your Turbo builds up PSI... Where is the PSI being measured at? Thanks guys!! (Just questions I've been wondering for awhile about)
Old Mar 15, 2002 | 04:01 PM
GSpeedR's Avatar
Default Re: Flywheel Vs. Wheel (Gozzy)
The flywheel is a rating (usually unbacked, from the factory) of horsepower which the engine makes without the drivetrain attached. There is typically a 20-25% power loss through the tranny (moving parts are susceptible to friction etc.) and which is measured at the wheels using a dyno. So they are measurements of the same thing, simply at different "stages".
About the turbo, I'm pretty sure that the pressure is measured at the turbo manifold, though I could be wrong.
tobe1424
Sep 27, 2006 07:37 PM
!0SeCoNdSleEpEr
Mar 4, 2004 05:23 PM
!0SeCoNdSleEpEr
Mar 4, 2004 03:29 PM
integraautox
May 25, 2003 09:31 PM
HX_Guy
Jul 28, 2001 02:05 PM
