Ek Rear Trailing arms onto EF *SEARCHED*
Old Dec 11, 2005 | 08:37 PM
slammedcivicsi's Avatar
Default Ek Rear Trailing arms onto EF *SEARCHED*
EDITED
What e-brake cables should I use. I have both the EK and the EF ones.
Will the OEM EK rear trailing arms bolt onto an ef chassis.
I ask because I have a set.
I understand the toe will be out, but thats what the alignment arm from the EF trailing arm is for right ? If I swap that over to the EK arm I should have proper alignment.
Im just curious if it will work as an assembly.
Thanks
Modified by slammedcivicsi at 2:49 AM 12/19/2005
Old Dec 11, 2005 | 09:46 PM
silentdork818's Avatar
Default Re: Ek Rear Trailing arms onto EF *SEARCHED* (slammedcivicsi)
It will work. Just make sure you use only the EK trailing arms by themselves. You need to use all the EF control arms for it to work. An alignment shouldnt be necessary assuming you didnt loosen the alignment bolt on accident.
Old Dec 12, 2005 | 06:21 AM
Default Re: Ek Rear Trailing arms onto EF *SEARCHED* (silentdork818)
thanks, I'll give it a shot, and hope for the best !
Old Dec 18, 2005 | 05:50 PM
original post has been edited.
but
And bump for fresh info.
Old Dec 18, 2005 | 09:09 PM
Default Re: (slammedcivicsi)
The EF cables are the right length for the car. You might be able to use the EK ones if you really had to though.
Old Dec 20, 2005 | 04:43 PM
thanks again, I'll just use my EF ones.....I just had both, so before I waste anytime making them work, I'll just use the EF oens.
Old Dec 20, 2005 | 05:08 PM
badboyr66's Avatar
Wow I was wondering this info myself. I have a 88 so I will need to swap the control arms out too... want to use coilovers
Hybrid_ek
Suspension & Brakes
14
Jan 6, 2013 09:02 AM
Rhonda14
Suspension & Brakes
Apr 5, 2011 11:11 AM
FS_WTB
Mar 13, 2005 05:57 AM
tnd2gen
11
Oct 10, 2003 03:43 AM
