valve adjustment and clearence?
Old Dec 11, 2005 | 07:08 PM
aser1z's Avatar
Default valve adjustment and clearence?
i have a 2nd gen b16 motor with a 5 angle valve job, spoon 2 layer headgasket with ctr cams.i adjusted my valves a while back and left them a bit loose.yes my valves tick a bit but no biggie.but i know that means a bit of comprssion loss=less horsepower.what gauge should i use to adjust the clearence?should i use the same size gauge and clearence as the 2001 itr specs?
Old Dec 12, 2005 | 03:59 AM
T.J.'s Avatar
Default Re: valve adjustment and clearence? (aser1z)
intake .007 exhaust .008
Old Dec 12, 2005 | 04:05 AM
96CivicBoostCoupe's Avatar
Default Re: valve adjustment and clearence? (T.J.)
What He Said ^
Old Dec 12, 2005 | 05:06 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: valve adjustment and clearence? (96CivicBoostCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T.J. &raquo;</TD></TR><TR><TD CLASS="quote">intake .007 exhaust .008</TD></TR></TABLE>
Thats in MM by the way. Use an angled feeler gauge, and go from the center, where the spark plug holes are, not from the outside, to get an accurate reading.
Old Dec 12, 2005 | 06:42 AM
EGmikeH22's Avatar
* B A N N E D *
you have the same compression with more gap
Old Dec 23, 2005 | 02:09 AM
ej2civic's Avatar
Default Re: valve adjustment and clearence? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
Thats in MM by the way. Use an angled feeler gauge, and go from the center, where the spark plug holes are, not from the outside, to get an accurate reading.</TD></TR></TABLE>
umm, not it is not in MM, those are inches...
b16integ
Nov 15, 2006 09:26 PM
BLacK FirE
May 24, 2006 05:30 PM
onyx00
Nov 6, 2005 01:50 PM
komat
Jun 16, 2005 04:51 AM
VtecXtreme
Jul 17, 2002 10:31 PM
