Ball joint camber kits?
Old Dec 11, 2005 | 06:43 PM
Trumpster's Avatar
Default Ball joint camber kits?
When I was in at my local alignment shop getting it aligned, I briefly had a conversation wtih them about camber kits. They were talking about heating up and bending the knuckle which I wasn't for at all although it would work and they also said that ball joint camber kits worked very well but wore out sometimes as quickly as 3-6 months. Does anyone have any experience with these kits that can give me accurate info? I would assume that they would just wear out just as your standard ball joint. Any info/input is much appreciated. Thanks all.
*edit*
I know the underglow is on the ricey side just a bit, but that's why I don't use it often. Try to bear with me on that one. lol. I hate a ricey car just as much as the next guy (or girl for you lady tuners out there).
Modified by Trumpster at 9:33 PM 12/20/2005
Old Dec 18, 2005 | 05:28 PM
gianinline's Avatar
If it is a really cheap, may not be so good... maybe because is remanufactured or something...
Old Dec 18, 2005 | 06:40 PM
flight50's Avatar
Default Re: (gianinline)
i got spc's ball and joint's on my ride. it has been well over 3-6 months and still going strong.
Old Dec 19, 2005 | 09:20 AM
maroonaccord2.2's Avatar
Default Re: Ball joint camber kits? (Trumpster)
The upper ball-joint type camber kit is what you want. I have a sport drop with the concentic camber kits that move the factory a-arm out.....now every so often I can hear the a-arm rubbing on the inner fender. I just need to jack up the front and gring the tips of the a-arms down a bit. I have a 1.5" drop in the front, with almost all of the negative camber adjusted out.....This is what I have:
Old Dec 19, 2005 | 09:24 AM
hondadude's Avatar
Those camber kits are pretty good, they don't wear like a ball joint because they are adjusting the pitch/angle of the upper control arm, I'd say they'll last a long time All the local parts stores around my area carry them. Don't let those monkeys torch the knuckle it will cause a weak spot.
Old Dec 19, 2005 | 04:29 PM
gianinline's Avatar
Default Re: Ball joint camber kits? (maroonaccord2.2)
yes... that's what I got!
Mine are made by CP products... and it works fine.. I mean... camber is still 0 degrees and I got the dropped a couple of inches too!
Old Dec 19, 2005 | 08:59 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (flight50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flight50 &raquo;</TD></TR><TR><TD CLASS="quote">i got spc's ball and joint's on my ride. it has been well over 3-6 months and still going strong.</TD></TR></TABLE>
I 've installed those on a few customers cars and havent had any of them come back. Seem to be pretty good. Especially for Accords.
Old Dec 19, 2005 | 09:58 PM
Trumpster's Avatar
Default Re: (cb7-R)
Thanks for all the input guys, it's much appreciated. As to gianinline's comment about them heating the knuckle, I didn't like that idea as soon as it came out of their mouth. lol. I have that same kind of camber kit currently that pushes the upper control arm out and it works pretty well. I may go with maroonaccord2.2's idea of slightly grinding down the end of the control arm for more clearance. Both my upper ball joints are shot right now because I used a pickle fork to separate the joint from the knuckle, not such a good idea there. It basically tore the ball joint straight open. I have one new control arm now so I may as well just get the other side and replace them both.
If you guys have any more input on the grinding a bit off the tip off the control arm idea, let me know. If I only take a small amount off (1/4'' or so) it should be fine and help with the camber but if anyone thinks otherwise, throw your opinion out there. Thanks again for all the input, this is why I like Honda-Tech.
Old Dec 20, 2005 | 08:11 AM
Default Re: (Trumpster)
With all of my camber adjusted out (0 degrees) my a-arms barely touch....You may only need to remove 1/16" to an 1/8" or so.... That is, if you are using a sport drop.
Old Dec 20, 2005 | 12:14 PM
Trumpster's Avatar
Default Re: (maroonaccord2.2)
I'm on adjustable coilovers with about a 2.5'' drop. About .5 degree upwards to 1 degree of negative camber wouldn't bother me since I want to take it a bit lower. I just don't want anything over 1 degree. Although people say that camber doesn't wear your tread unevenly, just toe does, I still believe that it has something to do with it. I'm riding on 17's with low profiles and I have about 2 and a half "fingers" of room above my front wheels and almost 3 above my rear wheels. I'll try to get a pic posted in here soon so you guys can see.
garyc17
Suspension & Brakes
Apr 13, 2008 08:39 AM
ESCALVANTE
Jan 31, 2002 10:36 AM
