hooking vtec up for swap?
Old Dec 11, 2005 | 04:29 PM
SlimBB4's Avatar
Default hooking vtec up for swap?
hey everyone. i swapped a 95 h22a1 into my 93' prelude s model. i cant figure out how to hook up the vtec. any help is apprecaited. thanks
-Zac
Old Dec 11, 2005 | 04:38 PM
SteveoBA8's Avatar
Default Re: hooking vtec up for swap? (Abstractlude)
Check out the prelude FAQ's man how to wire is in there, ok for your S model you need to wire.
1. vtec solenoid- ecu pin A4
2. vtec pressure switch-D6 and its ground- on thermo housing where ecu main ground is.
3. Iab's -Ecu pin A17 pink wire. Make sure you are getting 12volts from the yellow/black wire on the engine harness connector for the iabs
4. knock sensor-ecu pin D3
Are you re-using your f22a1 engine harness?
Old Dec 11, 2005 | 04:57 PM
herovueboi's Avatar
https://honda-tech.com/zerothread?id=1004852
Old Dec 12, 2005 | 06:37 AM
SlimBB4's Avatar
Default Re: (herovueboi)
thanks a lot guys, i didnt mean to be like everyone else and not search the subject. i ran some quick searches but the search thing on this site sucks. i was a little pushed for time yesterday too, but thanks for all your help.
-Zac
oh and yes i am re-using the f22 harness.
Old Dec 12, 2005 | 08:46 AM
herovueboi's Avatar
I always refer to the FAQs first because I've been told to search too many damn times. I could understand though, sometimes you just don't know which words exactly to search for and end up getting a ton of threads and usually being too lazy to scope out all of them. You'll eventually learn, I hope master the search function. Though it doesn't hurt to make a new thread every now and then.
TeamRPM_ZC
Jul 14, 2008 08:36 AM
GreddyCivic7
Feb 10, 2007 03:35 PM
mxer518
May 8, 2005 03:00 AM
lilbluehatch
12
Apr 16, 2005 05:43 PM
labatia
May 20, 2004 06:37 PM
