B16 block GSR Head
Old Dec 11, 2005 | 03:44 PM
JspecCivic94's Avatar
Default B16 block GSR Head
I have a B16 Block and GSR Head and I found out there are PR3 B16 Cams in my GSR Head, would GSR Cams or ITR Cams make a difference if I was to change them out?
Old Dec 11, 2005 | 10:57 PM
Andrew619's Avatar
I would like to know this to
Old Dec 11, 2005 | 11:56 PM
pouponu's Avatar
Default Re: (Andrew619)
YEA I WOULD DEFENTLY THINK ITR CAMS WOULD HELP THINGS OUT ARE YOU SERIES....EVEN CTR CAMS WOULD BREATHER BETTER BUT I SEE A LOT MORE USE OF ITR CAMS
Old Dec 12, 2005 | 08:15 AM
Golden Eagle's Avatar
Default Re: B16 block GSR Head (JspecCivic94)
yes the itr cams will make a difference
Old Dec 12, 2005 | 08:24 PM
onepoint6i's Avatar
avatar jack move
Old Dec 12, 2005 | 08:50 PM
Sliced Beard's Avatar
Default Re: B16 block GSR Head (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pouponu &raquo;</TD></TR><TR><TD CLASS="quote">YEA I WOULD DEFENTLY THINK ITR CAMS WOULD HELP THINGS OUT ARE YOU SERIES....EVEN CTR CAMS WOULD BREATHER BETTER BUT I SEE A LOT MORE USE OF ITR CAMS</TD></TR></TABLE>
turn caps lock off!!!
ITR and CTR cams are identical, GSR cams would be best for your situation due to the fact that you don't have very much compression and you are not tuning your vehicle.
I would also reccomend that you get a skunk 2 intake manifold for your GSR head so that it will flow better into the head.
staindgd
Jan 28, 2008 06:28 PM
SilvrBullet GSR
Oct 17, 2007 09:42 AM
Tuahe556c
Apr 18, 2006 10:00 AM
EJ8 GSR-T
Feb 22, 2006 04:33 PM
Stingray96
Dec 18, 2005 09:34 AM
