Negative caster? Alignment sheet inside
Just got my alignment recently. How does it look? My camber is still out of specs because the car is too low and they adjust it to the max on the omni power camber kit. Caster is out of spec too and is negative. From what i've found is if i swap the UCA to the opposite side it will give me a little bit of positive caster? And when i install my DTR-fab traction bar it might help with the caster also? Am i correct on the info?
Left side Right Side
Camber -1.7 Camber -1.5
Caster -0.6 Caster -0.8
Whats the ideal specs for drag racing?
alfaaay
Mar 21, 2003 06:30 PM
