Oil Leaking Inside distributor?
Old Dec 11, 2005 | 02:52 PM
s2kkid's Avatar
Default Oil Leaking Inside distributor?
I got a problem Ive never really heard of happening before, atleat to anyone i know.
I noticed oil on the bottom of the distributor, a drop or two t be exact, I pulled off the cap, and there was some oil in the bottom inside.
Is the seal for the actual distributor(not the o-ring) going bad? Is there any way to replace it without buying a new distributor?
Old Dec 11, 2005 | 02:54 PM
Dartanian's Avatar
Default Re: Oil Leaking Inside distributor? (vtecluder97)
Yeah, there is an oil seal inside when you take the valve cover off that you just need to replace.
Old Dec 11, 2005 | 04:08 PM
Chubz's Avatar
Default Re: Oil Leaking Inside distributor? (Das Schmoo)
replace the rubber o ring on the distributer, its on the end that goes intot he intake camshaft
Old Dec 12, 2005 | 12:20 AM
s2kkid's Avatar
Default Re: Oil Leaking Inside distributor? (Chubzilla)
Thats already been replaced recently, Im asking does the shaft that spins in the distributor have a seal internally?
Oil is INSIDE the distributor
Old Dec 12, 2005 | 06:17 AM
91integraLSVTEC's Avatar
i also have the same problem. i also replaced the distributor o-rings. bump for some answers.
Old Dec 12, 2005 | 06:42 AM
TurBoTeG's Avatar
i love how everyone can read......
anyways....i personally wouldnt worry about a small drop or two. I just checked the Acura site and it does not sell any other seals for the distributor other than the one you have already replaced. If it gets worse it will be time for a new distributor IMO
Cameron k.
60
Sep 25, 2012 07:19 PM
blackmfoggie
Aug 23, 2007 12:09 PM
porsche997dc2
Dec 22, 2003 08:49 PM
porsche997dc2
Dec 22, 2003 05:14 PM
krshultz
Feb 9, 2002 04:21 PM
