how many of you have installed a bad thermostat
just like the title says . i know i have bought 2 bad ones before from autozone both times. the recient one sticks and this morning i went to troubleshoot the cooling system and confirmed the new thermostat wasnt opening(radiator was cold to touch as well as lower hose , car was well above normal operating temp). im just curious how often this occurs.
most aftermarket thermostats are garbage, i had this problem a few times before. Stick with an oem honda thermostat, its $15 from the dealer and includes the gasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT »</TD></TR><TR><TD CLASS="quote">most aftermarket thermostats are garbage, i had this problem a few times before. Stick with an oem honda thermostat, its $15 from the dealer and includes the gasket</TD></TR></TABLE>
is spoon and mugen considered aftermarket thermostats? any diff between them and oem ones?
i think honda has 2 one opens at a slightly higher temp.
if i rember right been over a year when i did mines.
used an pep boys one once only lasted a few months.
spoon and mugen open earlier to keep temps lower.
my honda one isnt sweatin one bit , glad i ditched the autozone one. i think ive learned my lesson . after the second or third thermostat thats bad from autozone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">my honda one isnt sweatin one bit , glad i ditched the autozone one. i think ive learned my lesson . after the second or third thermostat thats bad from autozone.</TD></TR></TABLE>
w3rd..i hear you...never again...lol
Munkyw3rkz.webs.com
happens a lot.... but once u find a decent one it will last.. mine did!
HONDA HAS 2 different thermos..... the SI ones are lower then GSR/ITR etc if i remember right
IMO you can't go wrong with an OE termo on a street car. Remember that lower temp is only a good thing to a certian degree. IMO you should only go with a lower temp thermo if you are also runnign a radiator cap that allows you to get more heat out of the system.
Yes I know that sounds strange, but I don't feel like going into the thermodynamics of a motor right now.
Thunder Cat
Dec 28, 2005 05:43 AM
scratchline20
Jul 2, 2003 01:20 PM
